Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
Error Contacting Update web service
I am attempting to connect to our wireless network, and am gretting the following message
Error Contacting Update Services: An error message cannot be displayed because an option resourse assembly containing it cannot be found.
Unable to start application in correct state.
(Any help that you can provide would be greatly appreciated- and thxs in advance)
Expert Level - Newbie
  • 12 Answers
I don't know what program you're using, but usually when you get the message "An error message cannot be displayed because an optional resource assembly containing it cannot be found", it is because the program is using the .net compact framework but the file System_SR_ENU_wm.cab has not bee installed on the device yet. That .cab installs the resource file that is missing. Once it is installed on the device, you'll see a better error message than the one you're seeing now.
Thanks,
Brad Radaker
Radicomm (maker of QuickTalk - push-to-talk for the MC9090)
www.radicomm.com
Posted on May 13, 2009
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
I am trying to connect to the web with my new sylvania ce netbook and it has the right password in it I click the internet icon says connecting the shows up unable to connect. Can you help me or should I...
Using the Personal computer to arrive into network requires turning on the device that would have a password to display the system windows. After the computer turns on though would have required a computer user password or possibly not, locate an internet explorer icon whether example; google, mossilla fox pro, chrome, netscape, internet explorer, are just network interface where network features would show up on. 2. clicking on the internet icon should require a password if built to require user pass before joining a network. 3. The password would possibly been disabled in some instances, where for example clicking on the internet explorer icon should simply display a page welocoming the network required. For example, if the internet explorer icon is clicked showing display page momentarily, then www.Google.com is typed in the search space of the page displayed, a connected network should show another page displaying the features of the page or site google show mometarily after search space has been click. An unconnected network would always display a message or network unavailable or internet not setup and requiring establsiment. The most situation would be a message communicating the cause of network malfunction. if the computer has a network subscription plan, for example a provider that has promised to network the computer in question for fees, where would have provided the computer user an installation kit either software to install on the computer to be linked to a network. The computer with networking defaults would turn on completely only after which just cannot network into another setup when a page is clicked onto it. Simply, ask your network provider for further assistance.
The following are network providers to contact for subscription and technicallities involving computer telecommuncation.
Cricket wireless services
AT & T wireless services
T-Mobile wireless services
Verizone wireless services
Pocket commication services
Trac wireless services
Boost mobile wireless services
Visit any locations to inquire about networking functionalities to phones or computers or contacting online by email or phone with questions of connectivity
Dec 04, 2010 | Computers & Internet
Tip
How to set up the Xbox 360 Wireless N Networking Adapter
Overview
If you connected to Xbox LIVE after October 28, 2009, a software update was installed on your Xbox 360 console to support the Xbox 360 Wireless N Networking Adapter. If the update was installed on your console, all you need to do is to configure the wireless settings. To learn how to do this, please see the following article:
908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
If you have not connected to Xbox LIVE since October 28, 2009, you will need to use the installation disc included with your Xbox 360 Wireless N Networking Adaptor to install software on your Xbox 360 console.
To install the software for a Wireless N Networking Adapter
1. If an Xbox 360 Wireless N Networking Adapter is plugged in to your console, unplug it.
2. Insert the installation disc included with the Xbox 360 Wireless N Networking Adaptor into your Xbox 360 console.
3. Turn off the console.
4. Turn the console back on.
The software update should start automatically. If the update does not start automatically, the software might already be installed.
Note If you receive a mixed media error message, please see the section titled "Mixed media error message" below.
5. When you are prompted to install the software, select Yes, update now.
6. If a network cable is plugged in to the back of your console, unplug it.
7. Once the installation is complete, plug the Xbox 360 Wireless N Networking Adaptor into the USB port on the back of your console.
For information about attaching and configuring your wireless adapter, please see the following article: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
8. Remove the installation disc from the disc drive.
9. Turn off your console, and then turn it on again.
If you receive a mixed media error message, auto-play might be turned off. Here’s how to turn it on:
1. On your console, go to My Xbox, and then select System Settings.
2. Select Console Settings.
3. Select Auto-Play.
4. Select Enable.5. Repeat the steps for installing the wireless adapter (above).
Next step:
For information about how to configure the wireless settings on your console, please see the following article: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 consoleDo not try to repair the wireless networking adapter.
Do not take your Xbox 360 console or accessories to a retailer for repair or service unless an Xbox support agent instructs you to do this.
Do not try to disassemble, service, or modify the Xbox 360 console, the power supply, or any accessories. If you do this, you might put yourself at risk of serious injury or death from electric shock or fire. For your own safety, such actions will void your warranty.
on Mar 04, 2010 | Video Game Consoles & Games
Unable to use the wireless setup wizard - I am trying to connect my pc with my wireless printer. When I try to use the setup wizard on the pc it says depending on the wireless software installed on this pc...
The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article. This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP 313242 How to troubleshoot wireless network connections in Windows XP
Feb 26, 2010 | Acer Aspire One PC Notebook
How can i connect to the msn messenger / google talk
I believe this may be a problem with your handheld device or handheld wireless service and not either of your broadband routers. Your particular PDA does not utilize the same wireless technology that your PCs and laptops do. Your PDA works with GSM,gprs & GPRS technologies. While laptops and PCs most commonly use 802.11a/b/g technologies. In summary, your PDA does not go to the Internet through your broadband routers. In fact, other than connectivity through bluetooth or USB, I doubt your PDA has any interaction with any devices connected to the broadband routers. Now, why can you not access certain services on your handheld? It may be that you are not connected to the right network with your service provider. It looks like this devices works on the Cingular network. There are 3 types of networks available. GSM, which is used primarily for voice traffic. gprs (note the lowercase), which is used for simple text messaging. And GPRS (note the uppercase), which handles all the other types of data transfer, including browsing the web and chatting. First, you may want to check with your service provider that you have an active plan that supports Internet surfing and chatting, such as GPRS (note the uppercase again). Second, once this has been confirmed, make sure the network indicators on the PDA show that you are connected to the GPRS (and not the GSM or gprs) network. Only when you are connected to the GPRS network, will you be able to utilize all the features of your PDA (voice calls, text messaging, and e-mail/web browsing). One way to force the PDA to get on the GPRS network is to just resset the wireless antenna. Second would be to reboot the device. If neither of those work, I would recommend contacting your service provider, as they will be able to help you trouble shoot PDA and network issues further. More info can be found here: https://onlinecare.cingular.com/support/setDevice.do?universe=cingular&make=HP&model=iPAQhw6515&x=42&y=0 Or call here: 1-800-331-0500
Sep 06, 2006 | D-Link DI-707P Router (DSDLDI707P)
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
465 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
justwinwin
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
