Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Vega KV-34HS420
Picture originally went black/sound off and status light blinked 7 times. The repair person replaced two IC regulators and said it didnt fix the issue. He took the board with him to further diagnose. He called and stated I need new high voltage transformer and it isn't available as part anymore but only available on a complete circuit board (the DZ board #A1302936A) for $300. I owe another $100 for diagnosing not including the board.
I called Sony and the board is available for $169 but they stated the high voltage or flashback transformer isnt part of that board. Now I am lost. Am I being taken for a ride by the repair man? Any help would be appreciated.
  • mmuuzzyy May 08, 2008
    I have the same exact problem kv-34hs420. T.V. just went black out of the blue and stand-by light blinks 7 times. This really sucks. I have the extended warranty from Best Buy and they are coming out on May 16, 2008. Today is May 8 so if you can wait 8 days I will post the results so you have a better point of reference for your repair. 8 days no play-offs!!
    Good Luck!!
    MUZ
  • gerardausten Dec 24, 2008
    I have the same problem. Sony recommended 3 repair shops. I was told it was the D board estimated repair cost $500 approx. I am dumping the TV and getting a 32" LCD for about the same cost.
MUZ,
Any luck with your TV yet?
Posted on May 21, 2008
MUZ,
The board I was told held the bad part was on the bottom left looking at the back of the TV. Please let me know. It would be appreciated. Thanks.
Posted on May 09, 2008
    Problem Solver:
  • 22 Answers
It's better if you bring you're tv to sony service center and ask to an authorized repairman
Posted on May 08, 2008
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony wega kv-34hs420 worked fine last night never had a problem with it before. Today i went to turn it on and i get no picture and the stand by light is blinking 6 times every cycle
your tv has problem in the horizontal circuit caps in the horizontal circuit should be checked also the jungle ic.and the regulator in the power supply.have a tech repair your tv if your are not a tech. good luck.
Aug 11, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No power up light blinks 7 times
this is a high voltage shutdown.......the high voltage has exceeded 33k,.....it causes the unit to shutdown for safety.check the power regulation as well as horizontal circuits.hope this helps
Feb 18, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a Sony Wega KV-34HS420 TV that takes several tries to turn on. When I push the power button or remote power on I hear the normal click and the sound comes on for 3-5 seconds but then I hear a second...
Since the set appears to "recover", it suggests either a poor solder connection or bad cap somewhere in the power supply. The 7 blinks indicate the problem circuit is in the horizontal area. Check the regulator (STRxxxx) IC in the power supply. If you do not have experience working with TVs, please refer this repair to a shop. The regulator IC costs around $25.
Dan
Nov 16, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Red LED light blinks 7 times when the set is turned on; no pictur
if you have the circuit diagram of your tv,check the horizontal polarisation IC closer to the line transformer and replace it.If it doesn't work,send the question again.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron
check the heater as your tv is ON, there must be a yellow light at the rear of the CRT tube. If the heater is ok then check the IC jungle side. resoldering the leads sometimes will solve. If not refer to your local Tech.
Jul 31, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
The 7 blinks indicate an over voltage condition. The high voltage section has exceeded 33,000V. This is generally caused by a bad regulator. I don't have a listing for your model, but there should be a multi-pinned IC attachd to a heatsink marked STRxxx located close to where the AC cord comes into the set. Post the actual marking here and I'll get you the part number and cost. That is the regulator that may be the problem.
Dan
Jul 15, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Feb 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
502 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
