Question about Intel Motherboard
THE MCH IS OPERATING WITH DDR2 667/CL5 IN SINGLE CHANNEL MODE Problem
The mch is operating with ddr2 667 cl5 in single-channel mode
Do you have a pair of matched RAM modules installed? Dual channel only really works with a pair.
Aug 03, 2014 | Intel Computers & Internet
How do I get bios to use the files in a usb to help restore the missing OS
The usb drive must have the boot file for the operating system there are videos on youtube shows you how to make a bootable operating system on usb
Sep 11, 2012 | ASUS Eee PC 1015PEB 10.1 Netbook 1.66GHz...
Yes I know that order into whitch slots i should put the memory stics,1 and 3 or 2 and 4 but CPU-Z isshowing me everytime that the mobo is running in sinle mode?????
CPU-Z might mean that your computer is running in "Single" Channel. Running in dual channel mode is slightly faster. Maybe 5% or a little more. To run dual channel you need 2 sticks of identical DDR ram. Your PC might have 2 non-identical memory sticks that's why it runs in Single Channel.
Mar 28, 2011 | Computers & Internet
My abit IL9 Pro says it's running in "single channel mode"... how do I make it run in dual channel mode?
its showing tha memory running in single channel that means u have one ram thats fine
if you want more install another one ram
Jun 20, 2010 | Abit IL9 Pro Motherboard
Hi, does any one knows about which type of RAM is suitable for the mother board MS-7168 VER 1C for the HP PC and whats the max capacity mine has only got a 512mb and i can see it has four ram slots in the...
Here you go....
CPU Support
  • Socket 939
  • Support AMD Sempron, Athlon 64 and Athlon 64FX processors.
  • Support 800 and 1000Mhz HyperTransport (HT) interface speeds.
System Memory
  • Four 184-pin DDR SDRAM DIMM sockets.
  • Serial Presence Detect
  • Support for single-sided or double-sided DIMMs (DDR 333 / DDR400)
  • Support for up to 4 GB system memory
  • Asynchronous HyperTransport and memory controller interface speeds
  • Supports dynamic link width and frequency change
  • Non-ECC RAM (ECC memory will run in non-ECC mode)
  • Single and dual channel mode operation:
    • Single channel mode with single DIMM, non-symmetrical population or non-identical DIMMs
    • Dual channel mode with 2 or 4 identical DIMMs, populated symmetrically
Sirwriter
Nov 14, 2009 | Computers & Internet
TV WONT GO TO VIDEO CHANNEL
most inexpensive universal remotes will not operate input select functions. save yourself some hedaches, go to shopjimmy.com, enter yuor model# and buy an original remote, my dear! you'll thank me later! :) mch
Mar 09, 2009 | Philips Magnavox MS2530C 25" TV
Memory
No. It means that your system uses single channel memory rather than the dual channel DDR2 RAM. Hope this helps.
Jan 22, 2009 | Intel D102GGC2 Motherboard
Tv stuck on video
most universal remotes will not operate menu fuctions or allow input selections. try using channel down buttton on tv . go all the way down to channel two then go down again to see if video1 or 2 comes up. if not access menu functions on front panel go to input select enter in manually mch
Jan 17, 2009 | Sanyo DS32224 TV
Subwoofers
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
2 x 2GB Kingston CL5 detected as 1 GB each one
Ok, I got it, Ur motherboard supports upto 8GB DDRII Dual channel
Try using these RAMs on other slots of the board to check if there is a problem with RAM Slot (As there are four slots on ur board).
If no success, try using RAMs on some other system to confirm whether problem is with RAM or Motherboard.
Mar 15, 2008 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Intel Motherboard Logo
3,482 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
