Question about Sanyo DP50747 50 in. Plasma TV
I have a Sanyo 50" plasma HDTV (Vizon) and I am having trouble with what my son calls "screen burn". Red dots trail behind images and the channel guide is somewhat visible in the corner. Can this be easily fixed? Or is it a sign that this TV is on it's last leg"?
  • smcc667 Aug 29, 2010
    Yes, but how much would this cost? Isn't there anything that could be done with the contrast or some other easy-to-get-to adjustment?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be the issue with Y-main however, buffer and the logic board should also be checked. These boards are located on the right side of the unit and to check them you’ll have to open the back of the unit. Once you have opened the back also check for any blown/bulged capacitors.
All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
  • Rylee Smith
    Rylee Smith Aug 29, 2010
    If there was I would have advised it to your already, the cost to get this repair will be around $200-$300 depending on the parts that needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Sanyo Master
  • 11,800 Answers
The red dots appear because the red section of the y-sus board can no longer generate the very fast switching voltage needed to drive the pixels - they are activated with a delay.
The channel guide is visible because its image has been literally burned in the pixels - this can't be fixed.
That tv is on its last legs - keep using it till you save enough money for a new one then junk (or donate) it.
  • Chris Bernier
    Chris Bernier Aug 24, 2012
    Axrael SRL, I have a Sanyo 50 inch model DP50747. I have a a wicked distorted screen with what looks like Paint Art as my picture. No matter which Input I am on. non of the colors are right and almost non of the image is intelligible. For example when using the menu, almost non of the characters can be read and all of the color is wrong on an individual Pixel level. You can identify kind of what the image is supposed to be, but can't really read anything. The color is mostly white but varies. Is this similar to what you are talking about in this repair thread?
Sanyo 50" plasma flatscreen, hdtv
Picture frozen on one picture for some channels and blank on others. Sound is on. What could this be? We have a 50" Sanyo. HELP!
Apr 13, 2011 | Sanyo DP32746 32 in. LCD Television
I got a new Sanyo Vizion 46" LCD tv as a present about 2 weeks ago. I noticed since the first day when I change channels I can still see some images of the previous channel I was watching. Should I...
Return the tv for another one for the replacement.This tv have a problems,call a delay prograssive scan.That why u see the jet trails of the previous pictures.This problems,will not go away,but will getting worse and even might have a permanent pictures screen burn of the previous pictures in LCD screen panel too.
Nov 29, 2010 | Sanyo DP46849 46 in. HDTV
When the Samsung 50" plasma TV is turned on and during the whole time the TV is running there is one small green dot (or light) in around the middle of the screen. It continues and does not go away as the...
Still under warrenty?Yes,call the tv manufacture,get this tv replaced quickly.The Plasma screen is developing a burn in dead pixels.This problems,can't not be repair.Except replaced the Plasma screen itself.The plasma screen panel are 90% of the tvs,not worth repairing,if it damages or broken.Will cost the same as a new tv,if the screen require replacing.Still under warrenty call it in right away to get the picture screen replaced under warrenty.
Oct 04, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Pink color horizontal lines comes on and off
That issue is with one or more of the board that drive the plasma screen. If you have a warranty, you will want to call LG for a free repair.
Sorry, but to trouble shoot that issue would require some TV tools and knowledge of electronics. There are several boards involved with processing the picture image to the plasma screen.
I hope this information has helped you.
Good Luck.
May 24, 2010 | LG 50PS60 50 in. Plasma HDTV
HP-R5072 50 in. HDTV Plasma Television: i have one red dot on plasma screen. it is always ...
Unless you see more red dots, this kind of "defect" is under specifications for this size of PDP, if you do not like it, the PDP module must be changed
May 17, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
I have a picture on the screen that will not go away.i change channels and the picture does not change
What you got here is called static images and unfortunately it will be hard to repair. Yes it can be repaired but it would be hard for one to do.
These static images are caused by things remaining on the screen called burn in this burn in can be taken out.
Here is something I use but does work 90 percent of the time and hope it helps you.
JScreenFix-to-Remove-Plasma-Screen-Burn-in">http://www.wikihow.com/Use-JScreenFix-to-Remove-Plasma-Screen-Burn-in
Click the link above follow the directions and I hope it works for you!!
Please do click the accept button for my efforts!
Dec 16, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
Mar 16, 2009 | Sanyo DP50747 50 in. Plasma TV
How to get digital and analog channels together?
Since the entire world has gone digital for the most part see no reason to hook up analog anymore
Jan 03, 2018 | Sanyo Vizon LCD-15A2 Television
Red Dots
Need to adjust some voltage on Power Board & Y-Main Board
Dec 10, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Red Dots on My Plasma.
Did you get this problem resoslved? I had the same issue a few months ago. I tech came by and took my TV to the shop, a few days later he said it was fixed as they needed to make some adjustments.....The TV has been fine up until a week or so ago and now the red dots have appeared again. Was wondering what happened to yours.
Dec 17, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Sanyo DP50747 50 in. Plasma TV Logo
974 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
