Question about Estate EED4300SQ Dryer
Wont blow hot air
I have a estate dryer and it wont blow hot air and also it was running all nite long
  • duke1966 May 07, 2008
    No heat! Everything else seems to work fine!
  • Anonymous Oct 09, 2008
    sometimes dryer heats when first turned on but then goes cold after 10 minute
    Genius:
  • 1,073 Answers
Check that you have 240 volts to the dryer terminal block
if so check the element and the element thermastats
Posted on May 07, 2008
No heat blows cold air, what is problem?
Check circuit breaker box Turn your dryer breaker off and then back on (reset) . If this doesn't help, does the dryer light go on
when opening the dryer door? Could be the High temp cut out
safety device because it's getting too hot.
Mar 16, 2015 | Estate Dryers
The dryer runs but will not blow hot air
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 04, 2011 | Whirlpool LEQ8000JQ Electric Dryer
I have an electric estate dryer that does not blow any hot air and continues to run and not shut off???
Greetings,
Unplug the dryer first for safety sake....remove rear cover and use an ohm meter to check the value of your heater and your safty thermostat....this dryer runs on 220 volts, but if only getting 110..it will still run, but heater will not come on....i suggest to check for voltage at terminal block...it should be 220...if not, check breaker or fuses getting back to heater element and thermal...check these and if bad, replace
I have seen the motor switch be bad and the timer as well...both these will cause a no heat problem...bet its the heater thermal or heater
Jan 20, 2011 | Whirlpool Dryers
The dryer hose fills with water, the lint trap never catches anything and the roof of the dryer gets hot but the clothes wont get dry. Any ideas? Thx
It sounds like you have no fan blowing. OR the vent is completely blocked so no air flow.
You could check fan by disconnecting the vent hose in back, and turn dryer on. Is is blowing a good volume of air? If so then you need to look at the vent. Any critter build a home in there? etc..
If there is no significant air blowing from the vent, you'll need to figure out why the fan is not blowing.
It's possible the fan is turning but is choked up and unable to move the air.
Perhaps the fan is bad, or there is a capacitor gone bad,.
That's as far as I can go from here.
Others may assist you further..
Dec 04, 2010 | Estate TEDS840JQ Electric Dryer
My dryer still rotates but it does not blow hot air and it contineously rotates. The only way it will stop is if I open the door.
first check for 240 volts at the dryer if it has an electric heating element,if you lose 1 leg of the 240 volts that leaves you with only 120 volts and with both your problems this is what it sounds like your problem is,because the motor is on one leg(120volts) the timer is on the other(120volt)leg and the element is on both legs at 240volts,so you lose 1 leg your timer or motor would qwuit and the heating element wont heat either
Jul 19, 2010 | Estate TEDX640JQ Electric Dryer
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Wont blow hot air
heating element failure 30 bucks and an hour of labor
Jan 14, 2009 | Dryers
WHERE DO I FIND THE HEATING ELEMENT ON A ESTATE DRYER
i have a estate dryer it blows hot air and drum turns but does not dry the clothes so it takes 3-4 rounds to dry the clothes what cold be the promblem
Nov 05, 2008 | Kenmore 63942 Dryer
Estate EED4300SQ Dryer Logo
150 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
