Question about Xerox Phaser 8500/DN Printer
Error code 31,001,40,153881
When the printer is switched on, it warms up to 1% and gives the error code 31,001,40:153881 - paper jam. I have checked for any paper in the printer, but there is no paper that is stuck in the printer. Can you please help?
    President:
  • 2,072 Answers
The electronics module has most likely failed.
It could be the paper path ( media drive assembly) , but most often that is a failure of the electronics module.
Posted on May 07, 2008
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Sir my printer samsung sf-565pr show error [jam 1] or [no cartridse] plz give me solution for this problem
Sounds like a paper jam check out the paper path going through machine. somewhere in there is some paper jamming a switch the cartridge is the printer head that holds the ink uinstall cartridge then reinstall . Then trace back what made it do this what happened the last time it worked. If nothing else go through the reinstallation process like you are hooking it up for the first time and that way you check all your cords make sure the paper tray is right and reload the driver and see , It is something simple one or all those things I mentioned.
Apr 01, 2011 | Samsung SF-565PR/XST Printer
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
After paper jam printer displays error light and will not function
1. Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Step 2
Turn off the printer.
3. Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
4. Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. Step 6
jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.6-800X800.jpg'); }); If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7. Step 7
jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.7-800X800.jpg'); }); If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything, though.
8. Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Mar 03, 2010 | Konica Minolta magicolor 2500 Printer
Cannot printer... it keeps giving me out of paper error, even when there's paper in the tray.
Sir,
Try these steps it may be solve your problem...
Step 1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2. Turn off the printer.
Step 3. Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7. If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step 8. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks
Good Luck
Aug 04, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Riso 3700 - Error Code G064
1 Power  swich off/on
2 Open and close front cover twise
Mar 22, 2009 | Office Equipment & Supplies
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Paper jam 11
Step1
Step
Step
Step
Step
5
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
Step
8
Step
9
Nov 07, 2008 | Copystar CS-1815 Printer
Paper jam
push menu then start mono (b/W) then 4x arrow-up button. maintenance should be displayed. What error code does the machine give to you?
Sep 11, 2007 | Brother MFC-410CN All-In-One InkJet...
Xerox Phaser  8500/DN Printer Logo
156 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
