Question about Bose Lifestyle 28 System
My ic L 4973D3.3 has burnt... what shud i do.. and where can i get a new IC
Hi, You could buy the IC on ebay from the link below..but how do you know this is the one your looking for. This sits on the Power board right.
Thanks.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280550094150&ssPageName=STRK:MEWAX:IT
Posted on Sep 04, 2010
How to solve horizontal lines on a CRT TV monitor and what could be the possible courses for it
Monitor horizontal lines problems usually caused by a defective vertical output/driver ic. A missing supply voltage to the vertical output ic may caused similar faults which is one horizontal line across the display. Dry joints and missing vertical output pulse from vertical oscillator ic also could contribute the same symptom. If you discovered that the protection resistor (usually from 1 to 4.7 ohm) open circuit or burnt, then replacing it won't solve the problem. The resistor burnt or open circuit was due to a short in the vertical output ic. Thus you have to replace the vertical output ic and the burnt resistor together before you switch on the monitor.
Jun 12, 2015 | Televison & Video
M-Audio AV20 smells like burnt
Yes, it is possible to burn an IC and not the fuse, because of Safety standards, the fuse has the function to avoid a possible fire, but it should deliver all the power needed by the circuit it is protecting, and that amount of power can burn, in this case, the IC.
From my technical point of view, there should not be a problem to connect the speaker to 110 V instead of 220 V, all that might happen is to have less power available at output, I have no idea about the reason of the burnt IC, but, as we all know, they (the IC's), don't need a reason to burn themselves whenever they decide to.
So, the next step, will be to replace the burnt IC, and that is not a simple task, you need a SMD station and some experience in doing such jobs.
Good luck and best wishes.
Apr 11, 2013 | M-Audio AV20 STUDIOPHILE
Model 42pfl3609/98. Why doesn't it turn on?
With all of those bad parts on PS sure there are more. Why not replace the board with a new one?
Mar 29, 2013 | Televison & Video
My Philips home theater model hts3105/98 is not working due to IC breakdown hence i need that ic number to replace it. hence please help me.
Every IC has their number printed on the top 1st line. If you have identified the IC, look for the number. If it is burnt & cannot get the number, you will have to refer the schematic diagram of the model. The service manual is available under following url. Just paste the following url in your browser , a download link is there.
http://new.eserviceinfo.com/downloadsm/54246/PHILIPS_HTS3105.html
sonsunny
Jun 17, 2011 | Televison & Video
*,#,o right cursor and down cursor r not working in my cell nokia-5130 i took it to the shop they sai that its ic need to be changed what shud i do???????
FIRST CHANGE YOUR KEYPAD BEALT ITS PRISE IN INDIA HALL SEL 120.00
THEN KEYPAD ICS PROUBLEM SO CHANGE KEYPAD IC ITS PRISE IS ONLY 20.00
BUT THE SHOP KEEPER SAYS ITS PRISE 200 TO 250
IDRISH 911
Oct 22, 2010 | Nokia 5310 Cellular Phone
The image disappears on my tv screen. A horizontal line appears.
You need to check the horizontal IC for deffects, possibly and most likely there are dry joints on the legs of the Horizontal IC. Have all the legs on the IC soldered nicely, this shud sort out your problems as you say you hit the TV then works. Try this before replacing the IC
Apr 16, 2009 | Televison & Video
Burnt resistors
Depending on where you bought the ICs you could have fried the new ICs when powering it up with burnt resistors as the green is controled by both ICs one IC controling the horizontal green Convergence and the other IC controling the vertical green convergence. Have you checked all the convergence resistors out of circuit?
May 18, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Bose Lifestyle 28 System Logo
47 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
