Question about Sony KP-57HW40 57" Rear Projection Television
Sony 57 inch
I just bought two convergance ics and replaced them and i am still having the same problem with the colors not being aligned, What could my problem be???
  • Sony Master
  • 8,617 Answers
Did you check the resistors and the 4 fusible resistors right next to the ICs? Often one or two will be open and need replacing with the ICs
Posted on May 07, 2008
My tv works it looks Like the picture is three inches to the right. It has a right shadow.
The tv have a problems known as a convergence pictures problems.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead to causes this problems.The tv convergence board must have be fixed.The tv convergence board must have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 24, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
PICTURE HAS GREEN AND VIOLET OUTLINING ON FIGURES AND DOUBLE ON WORDING
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows picture or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 04, 2011 | Sony KP-57WV600 57" Rear Projection...
Half of the screen if fuzzy and the other half is fine, how can i fix it?
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 17, 2010 | Sony KP-57WS500 57" Rear Projection...
The picture looks 3D and kind of curving in
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have pictures colors shadows or have a 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Green and pink wavy lines on screen
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures look alike.The tv convergence board have dead parts.The convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 27, 2010 | Sony KP-57WS500 57" Rear Projection...
My Sony kp57hw40 looks like it is in 3d after it has been on for awhile it goes back to normal
It starting to died.It will happen for good.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have pictures colors shadows or 3D picture look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The Shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Sony KP-57HW40 57" Rear Projection...
Wavy color separation, auto focus doesn't fix problem. Doesn't have a manual focus.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
Oct 11, 2010 | Sony KP-57WS500 57" Rear Projection...
The colors aren't lining up properly on my Sony rear projection tv.
Oct 06, 2010 | Sony KP-57WS500 57" Rear Projection...
Double picture out of alignment
Hi:
Your problem is its time to replace the convergence IC's. Replace both of them as if one has failed depending on which color is out of convergence the other is not far behind. They are the two large black IC's mounted on a large metal heatsink, also while replaceing them check the small yellow or green micro fuses underneath the IC's to make sure none of them have opened from the result of the IC failing.
Apr 30, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony 57 inch
Hello
there is two STK packs in your TV, this is what controls your convergence,it should be two big IC on big heatsink and number should start with STK- ______,just replace these STK packs and you can order these from matelectronics.com. Parts should be somewhere around $30 and also make sure that resistors around stk packs don't look like they been hot if they look like they been hot just replace them too, and your TV will be working fine.
Thankyou
May 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
41 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
