Question about Electric Cannon Mag 10 Hs Downrigger
I just bought a used boat. it came with Cannon Mag 10 Electric downrigger. The Down riggers came with a male electric cord end attached to the downriggers cord??? How should the downriggers be wired?
    Top Expert:
  • Electric Master
  • 43,020 Answers
Since 12 vo;t systems are 2 wire if you try it one way and its wrong just switch the wires
Posted on Oct 31, 2010
Cable jumps off of roller at end of boom
I've had the same problem with my electric Walker down-riggers, the line guides didnt work well because of the crimp for the cannon ball return pully snags on the guide, the best I came up with is a cannonball snubber similar to ones used with Dipsey-Divers, made heavier for cannonballs, hope this helps
Jun 04, 2012 | Electric Cannon Mag 10 Hs Downrigger
Looking for parts & service: mag 10A cannon downrigger
Your best bet for price is looking on ebay, there are lots of links off of an inquire.
Apr 12, 2010 | MAG Cannon Mag 5 HS Downrigger
IHAVE A CANNON MAG 5 AND THE CABLE RUST UP ON ME CHANGED CABLE AND IT DID IT AGAIN IN ONLY 4 HRS
Corrosion is caused by small amounts of electrical current flow following the path of least resistance and jumping off one piece of metal to another one thus taking a small piece of metal with it when it goes. You have to either eliminate the current flow or slow it down or make it go somewhere else. The positive ion control in these downriggers can probably add to the problem. Also if you're fishing in salt water, it is a natural electrolyte and if two differnt kinds of metal are in saltwater, they creat a natural battery and produce enough electrical current to corrode the metal. I would suggest maybe using a sacrificial anode. It's a piece of metal with lower resistance to electrical current flow than the metal you're trying to use, thus is corrodes the anode before corroding the metal you're protecting. Anodes are made of metals like aluminum, zinc and magnesium. If you had a small piece of one of those metals and wrapped it around the downrigger spool before you wound the cable onto it, it would rust it out before rusting your cable. You can also try turning down your Ion Control. I've seen my cable rusting a little bit but it doesn't seem to be that bad or rust so fast. I'm wondering if you're using a different kind of metal for your cannonball?
Oct 15, 2009 | MAG Cannon Mag 5 HS Downrigger
Cannon downrigger
score along the seam with a razor knife just below the cover where the screws are you need to reach an 1/16th inch deep insert a screw driver into the rubber gromet where the power cord goes in and pry open the cover be very carefull not to use any of the insides as a lever and use finess not brute force
Oct 04, 2009 | Cannon Digi Troll(Tm) Iv Eelectric...
A)will not work at all,had radio shack test out the fuse and switch;said they were fine,direct wired motor to batteryand the motor worked fine in both directions and b)have another downrigger that once the...
I may be able to suggest a cure for downrigger #1. The switches sometimes have several terminals and they work differently than they look.
For example, if you have 6 terminals, 3 on each side of the switch. The left bottom and right bottom are a pair. The middle two are a pair and the top two are a pair. Then you have terminals that are separate on the right side with the middle terminal being common and the pair being right lower and middle, right upper and middle with corresponding left side action.
This point being that the switch for unit #1 is good as tested by Radio Shack. Its where you stick the wires on the terminals that is the problem.
You need a multitester and use an OHM setting without juice flowing through your wires. This way you can figure out the pairings of the terminals without burning something up.
Aug 21, 2009 | MAG Cannon Mag 5 HS Downrigger
Used (older) Cannon Digitroll II Manual or advice
I have the quick start manual for digi-trol II. I will try to scan it and post later today.
Kevin
Jun 20, 2009 | Cannon Digi Troll(Tm) Iv Eelectric...
Cannon Digitrol 1V bottom tracking not working
Hello!
Here is the user manual for your downrigger:
DT IV Downrigger
The programming starts on page 12.
Best of luck!
Mike
Jan 14, 2009 | Cannon Digi Troll(Tm) Iv Eelectric...
Electric Cannon Mag 10 Hs  Downrigger Logo
340 people viewed this question
Top Electric Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you an Electric Fishing Expert? Answer questions, earn points and help others
