Question about Sport & Outdoor - Others
My new Samsonite Oyster 29" Cartwheel suitcase has a digital combination lock. The instructions says to use the lever behind the lock to set the new numeric combination. However the actual lock does not have a lever but two buttons A and B. How do you set the new combination?
  • 3 Answers
SOURCE: my combination for samsonite suitcase no longer works what to do?
Is it locked shut?
Posted on Jun 22, 2009
SOURCE: I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Posted on Oct 17, 2009
  • 10 Answers
SOURCE: Where can I get spare parts for Samsonite suitcases?
ebay
Posted on Nov 30, 2009
matt2414
  • 247 Answers
SOURCE: How do I reset the combination lock on my
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
Posted on Mar 19, 2010
SOURCE: suitcase number locked combination forgotten
how can i open my forgotten combination samsonite suitcase
Posted on Oct 09, 2010
How to reset a combination lock for samsonite luggage?
if the suitcase is open, look for a little red tab on the inside. Move it to the other side of the little window, then change the combination. If the suitcase is locked, you will have to try from the outside to find the correct combination
Mar 11, 2015 | Samsonite Photography
Samsonite oyster 1992 lock reset
This should help whether you know the old combination or not.
How to Open Combination Lock on Samsonite Suitcase
Jun 01, 2014 | Locks & Locksmithing
Roncato suitcase forgotten my combination and cant open the suitcase
I have a Roncato hard shell with a 3 digit combination lock under the handle. I set the combination YEARS ago, had a young child play "horsey" on it, and turned all the numbers! The suitcase was locked and I had forgotten the combination. I followed the instructions in answer 2 above and it worked! I didn't have to add or subtract 5. I used a small sewing needle and a strong flashlight - the indentations were easy to see.
Feb 11, 2013 | Samsonite Photography
How to change lock code in TSA007 lock?
Nov 30, 2012 | Samsonite Tripod
How do I reset a 4 dial Samsonite combination lock
Hello sstacy1,
You can follow the steps below to fix your problem on how to reset your 4 dial Samsonite combination lock:
  1. Set the dials to 0-0-0. Find the lever or button next to the dials.
  2. 2If your lock has a lever, lower it and turn the dials to the desired numbers. Return the lever to its starting position.
  3. 3For locks with a button, push the button towards the dials and turn them to the desired numbers. Release the button.
  4. 4The lock is now set to the new combination.
Read more: How to Reset Samsonite Luggage Combination Locks ' eHow.comhttp://www.ehow.com/how_4761466_reset-samsonite-luggage-combination-locks.html#ixzz157Q4Ap
Hopefully it helps.
Thank you for using fixya
Sep 08, 2011 | Health & Beauty
I want to set a combination for the lock
Jan 09, 2011 | Samsonite Silhouette 11 Hardside Spinner
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
Please tell me how to set teh lock code for my samsonite silhouette 11 HS....no instructions were included! help!!
Sure... here're the instructions - open the suitcase, then open the zipper in the modesty pouch (it is mounted on the backside of the suitcase, along its entire length), and then from in there, take out the plastic packet. In the plastic packet are labels, warranty information, AND voila - the instructions to set the combination lock... :-)
I would tell you here too:
1. Open the suitcase
2. Look at the inside back of the lock - you would see a red color tab, and two markings - A
Aug 30, 2010 | Samsonite Silhouette 11 SoftSide 22"...
Oct 16, 2009 | Samsonite Tripod
I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Apr 11, 2009 | Samsonite Tripod
Sport & Outdoor - Others Logo
70 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
