GOODMAN LD 2665 D Television. Have sound but no picture.Can you help?
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
How do I make the sound work
As you see in this picture, and AV cable will have these type of pins at both ends. Just see:
Like this. By which; Yellow colored one is meant to be connected to Video In to the TV, and the other end of it to the Video out of the device you do as source; like DVD,VCR LD player etc.
Similarly, the other two colored pins [2 of it] are meant to be connected to the respective colored sockets; both at TV & the source device. These two wires are audio connectors, Left & Right channel. It's quiet simple to connect; and no expertise is needed. Have keen look. That's all.
Gopakumar Gopalan Google
Sep 16, 2014 | Olevia LT27HVX 27 in. LCD Television
My daugther's apex LD television model3288 32" isn't displaying a picture. I connected it to another cable box and we still can't anything. She can't find the remote and the tv hasn't been used in ove
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 13, 2014 | Televison & Video
Blue Screen with numbers and letters.
Look for any loose contacts in jacks, cables, RC sockets, any jammed buttons on remote or on control panel.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Sylvania LD-155SL8 15 in. LCD Television
I have a Sharp LD-26SH3U 26. I have picture but no sound. I turned it off to go to work & when i came home it took awhile to even get picture, then the picture came on, but no sound.
A couple of thoughts here--you may have suffered a power loss while away--unplug set for a while and then power back to see if it helps.
As far as the sound it is unlikely but possible the speakers may have got switched off somehow--check in audio or setup menu to see if this is the case.
Apr 17, 2012 | Sharp LD-26SH3U 26 in. LCD Television
Need auto code for adobe acrobat 7.0 professional. s/n :1118 - 1212 - 2665 - 0540 - 1021 - 0150
serial number: 1118-1212-2815-3150-7574-7433
activation number: 7344-4821-7718-1179-5837-5925-2166
authorization code: ????
Mar 29, 2012 | Adobe Acrobat 7.0 Professional
Lock appear on Tv. Screen Blue. Sound audible
You Probably Need To Go Into Parental Controls And Change The Settings If You Forgot Your Code Go To Your Brand Name's Site And Find Your Tv User Manuel And Go Under Parental Controls
Hope This Helps = ) Tophee
Jul 16, 2009 | Sharp LD-26SH3U 26 in. LCD Television
Need this part
I get a lot of boards from a company called Vance Baldwin (www.vancebaldwin.com), and they sell Sharp parts. You might also try a Google search for the part number.
Nov 21, 2008 | Sharp LD-26SH1U 26 in. LCD Television
The green light on for 2 seconds and off again (Panasonic TH-42PWD5UY)!
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Jan 23, 2008 | Panasonic TH-42PWD5UY 42 in. Television
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
