Question about Olympus FE-170 Digital Camera
My lens will not go back in, i have checked the batteries they are fine.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
SOURCE:
My Coolpix L320 was working fine, then all of a sudden got stuck with the lens zoomed all the way out and a message on the screen that says, "Turn the camera off, remove the lens cap, and turn the cam
after changing the battery and gently push back on the lens it should automatically close if not then check around it it must be something stuck in between it
Jan 18, 2015 | Nikon Coolpix L320 Black Digital Camera...
Lens cap error message
hello,you actually need to remove the battery for a while,say about 10 minutes,check the contacts where the battery connects,if any sign of corrosion,then use a fine grade of wet and dry(available from any car accessories shop) and gently remove the corrosion,have the battery checked,as lithium batterys suddenly die off at a critical stage,although they appear to run for ages without any undue problems,replace with a known good battery,switch on your camera,but don't do any snapshots for a while,then switch off again,do this a few times,before you begin using the camera,as i had exactly the same problem,and cured my anomaly .hope that helps, cheers.
Jan 02, 2014 | Nikon COOLPIX L810
When I open the lens door the lens doesn't come out. So the camera is not activated. The battery is fine and I can still connect the camera to my laptop. Somewhere I read that there is a little battery...
no there is no such little battery in the camera.there is one battery in the back of camera from which the battery gets power.if the charge in that battery is less or that battery is weak or faulty then this same problem of lens not coming will occur.but if you are confirmed that battery is properly charged and its not weak.then the problem may be either the lens assembly getting blocked or there is a motor inside the back of the lens assembly.the motor actually makes the lens assembly go back and forth.if that motor is got weak then this problem can occur.so the problem is either lens moving assembly got blocked or broken or the motor is weak/faulty. that has to be checked. before going for any internal repairing and checking .just be confirmed that camera battery is properly charged and working.in many cameras it has been noticed that due to weak or faulty battery this types of many problem occurs and replacing the battery solves the problem. this will help.please do rate the solution.keep updated for any further assistance if required. thanks.
Apr 29, 2010 | Canon PowerShot S50 Digital Camera
It just turned on fine , i took out the batteries and memory card then put them back in. it wont turn on
check lens barrel for any dirt etc stopping lens coming out, this sometimes stops the camera turning on. make sure the batt is full (sure you have!) good luck
Dec 06, 2009 | Canon PowerShot A80 Digital Camera
Camera wont turn on and lens wont go in and i just put new batteries in
Lens of the Camera doesn't retract:
Before trying any of the suggestions, make sure that the Battery is
fully charged and in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,
then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed
air (20 lbs) set the tip between the lens turret and the camera body
and turn on the air while moving the tip around the lens. It should
remove all dust and sand. Turn the camera on and it should function
fine.s
3) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and
take a look at the spacing between the lens and the lens housing. If
you notice that the gap is not even all the way around the lens, the
problem should be easy to fix. This type of a problem usually occurs if
the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try
powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts
again, do the following.
(a) Turn the camera off.
(b) Take the camera in one hand and with the other gently take one part
of the lens and gently move it round in a circular movement. Do so with
both sections of the lens. You will hear a "click" as it pops back in
place.
(c) Power the camera on.
Another version of this fix would be to pull and twist on the largest
ring of the lens while turning the camera on. Listen for a "click". If
at first the focus seems to be off, turn the camera on and off and take
lots of pictures, close ups and distance. Focus should slowly start
improving.
Dec 02, 2009 | Kodak EasyShare C913 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Lens is stuck open
We had the same problem with a Casio Exilim. Had been stuck for months...had nearly given up until I saw another post about banging the camera pretty forcefully to get the lens unstuck. I hit it once on the bottom onto my desk(w/ paper and blotter on the desk-so soft), then twice with the back of the camera against the desk. I turned it on and the lens was unstuck!! Immediately took a couple pictures and it seems to be working fine! If the camera may be lost, you've got nothing to lose to try this out...Good luck!
Apr 26, 2008 | Casio Exilim EX-S500 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
My nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Aug 05, 2007 | Nikon D70s Digital Camera
Olympus FE-170 Digital Camera Logo
359 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
