Question about Nokia N97 mini Smartphone
WLAN is not working and the phone won't let me change the alarm i set. It says "System Error" every time I touch the "Time" option.
    Problem Solver:
  • 12 Answers
Try four finger reset http://www.nokiausers.net/forum/nokia-n97/32158-four-finger-reset-n97-mini.html
WARNING>>> Four finger reset will erase everything on your phone memory. my recommendation is not to perform it without backing up your cell phone contents via pc suite
Posted on Aug 29, 2010
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
Tip
Samsung Android secret code
This is secret code on Samsung <a href="http://www.androidmanual.net/">Android</a> phone. With this secret code you can access hidden phone information.<span></span>*#*#4636#*#* Phone Information<br />*2767*3855# Hard Reset*<br />*#*#7780#*#* Factory Reset**<br />*#*#7594#*#* Change End Call/Power Option<br />*#*#197328640#*#* Service Mode<br />*#*#273283*255*663282*#*#* File Copy Screen (Backup Media Files)<br />*#*#526#*#* WLAN Test<br />*#*#232338#*#* Shows WiFi MAC address<br />*#*#1472365#*#* GPS Test<br />*#*#1575#*#* Another GPS test<br />*#*#232331#*#* Bluetooth test<br />*#*#232337#*# Shows Bluetooth device address<br />*#*#8255#*#* GTalk Service Monitor<br /> Codes to launch various Factory Tests:<br /> *#*#0283#*#* Packet Loopback<br />*#*#0*#*#* LCD test<br />*#*#0673#*#* Melody test<br />*#*#0842#*#* Device test (Vibration test and BackLight test)<br />*#*#2663#*#* Touch screen version<br />*#*#2664#*#* Touch screen test<br />*#*#0588#*#* Proximity sensor test<br />*#*#3264#*#* RAM version<br /> Codes to get Firmware version information:<br /> *#*#4986*2650468#*#* PDA, Phone, H/W, RFCallDate<br />*#*#1234#*#* PDA and Phone<br />*#*#1111#*#* FTA SW Version<br />*#*#2222#*#* FTA HW Version<br />*#*#44336#*#* PDA, Phone, CSC, Build Time, Changelist number<br /> <b>Note :</b><br />* Hard Reset to remove all files and settings in internal memory, or equal to reformat the firmware<br /><b>* Warning! when it is direct push hard reset, there is no cancel option</b><br />* Factory Reset just delete the account, system & application settings
on Feb 02, 2011 | Cell Phones
Tip
Apple ios 4.2 for iPhone, iPad and iPod Touch
Why ios 4.2 ? Many iPhone and iPod Touch users have recently reported the alarm issues some users reported that alarm clocks are not working at all, which occurs due to the Daylight Saving Time (DST) change. Discussion on forums are still going on, Apple has now acknowledge the issue and released a support document which states that the users will be able to set the repetitive alarms after 7th November resolving the DST alarm bug.
How to Fix itune Error codes:1004,1015 and Restore iPhone 4, 3GS on iOS 4.0.1
on Nov 05, 2010 | Cell Phones
How to set an alarm on a Samsung T255G Phone?
Hi there!
You can set an alarm to alert you once, or daily at a specified time. Once set, the alarms are easy to change or turn off completely.
1. In Idle mode, press Menu > Tools > Alarms. The following options appear in the display:
• Wake-up Alarm
• Alarm 1
• Alarm 2
• Alarm 3
• Alarm 4
2. Select an Alarm. The alarm screen appears in the display containing the following options: the alarm name, the on/off setting, the time, AM/PM, alert type, alarm tone options, the alarm volume setting, days if the week to sound, snooze option and auto power on/off setting.
3. Highlight the options you wish to change, then select values for the options using the Left and Right navigation keys.
4. When you're finished entering and selecting values for the alarm, press ok. The alarm is set and the alarm icon appears in the top of the display.
Hope this helps
May 01, 2011 | Cell Phones
How do i change the time
The time and date are programmed through system programming. A 4015 phone cannot do this programming. A 4150 phone setup as a subattendant phone with the "attendant setup time/date" class of service option enabled for the 4150's class of service can change the system time and date. This is accessed through the LCD touch screen keys of the 4150. Scroll through the options in the screen until you find set time /date.
Also an attendant console with the "attendant setup time/date" class of service option enabled for its class of service can change the time and date. Press the function button then choose attendant function.
Choose set time. Enter the time in four digits as in 0800 for 8:00. Choose PM if needed. Choose set.
Choose exit to finish.
Dec 13, 2010 | Mitel Superset 4015 Corded Phone
"not allowed to dial"on f003 phone
hi mate,just follow these instructions 1. make sure to have 2 sims in phone(do not use 3g sims) 2. make sure wlan is disabled 3. enter engineer mode (type in *#3646633# 4.scroll up not down to number 10 RF test tool 5.choose gsm touch ok verify ok touch power scan 6.select band dcs 1800 press ok phone will go to test looking for DES(frequencies) wait until phone crashes or seems inactive(can take 3 to 15 min) press the end button (red one) phones with one middle button use that one phone will go off turn on phone and it will be reset to flight mode....(you can try to make call to verify,phone wil say cannot make call,not, not allowed to dial like before) go to settings and network setup,sim1 network setup,prefered mode and select gsm prefered...(phone will now change mode unlike before saying unfinnished) try the phone to make a call (should be no prob now) not finnished though .... go into settings again select restore factory settings (password 1122) wait for phone to restart...now its all done .....now you can change your tones and turn wlan on etc do not for any reason select wlan only or gsm only again...
Jul 19, 2009 | Dual Electronics CECT P168 Cellular Phone
CAN U CHANGE THE SNOOZE TIME ON THE ALARM CLOCK AND HOW?
you go to your alarm settings in there you will find the option that snooze time in there you will change the time for snooze
Jun 11, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
On button won`t work
In the Clock Alarm settings you should be able to set an alarm for the time you want your phone to ring to wake you up.
Switch off your PIN number. When the phone rings it will give you an option to start up or not.
Dec 25, 2007 | Nokia 6233 Cellular Phone
Razor alarm clock
Once you open alarm, select "set" for alarm 1, go to the time and change it to what ever time and click "set" again. After shut phone. I thought it was wierd that it did not confirm but It works. Let me know how it goes.
Cynthia
Nov 09, 2007 | Motorola Mobility RAZR V3
Nokia N97 mini  Smartphone Logo
167 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
