Question about Canon imageRunner C3100 Copier
Setting copier to default to black
I would like to set our copier to default to printing in black. I know it can be done, I just don't know how...any suggestions?
  • Eugene Malan
    Eugene Malan May 11, 2010
    Do you want "printing" as in printing from a computer to be in black, or copying or both
  • 86 Answers
In standard mode set the mode to black then
Press the * key with the circle around
Then select copier features
Then scroll through the pages and select standard mode
Then press STORE
If you require further assistance please get back to me
Thank You
Posted on Jun 23, 2008
How to change default copy and print setting to black instead of color
It is different for every brand and model. Post more detailed information about your printer and someone may be able to help.
Aug 31, 2014 | Office Equipment & Supplies
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
Is there a way for me to set my copier to default print black and white? I know this can be managed by each PC but sometime folks forget so i would like to deafult all print jobs to B/W unless otherwise...
TO SET THE MACHINE FOR BLACK AND WHITE ALLL YOU NEED TO DO IS SELECT BLACK ON THE COPIER PRESS THE UTILITY USER KEY THEN PRESS COPIER BUTTON DEFAULT BUTTON THEN SELECT CUREENT SETTING
THIS WILL DEFAULT THE MACHINE TO COPY IN BLACK TO SET PRINTING IN BLACK YOU CAN SET UP THE DRIVER TO PRINT IN BLACK ONLY
Jun 03, 2011 | Konica Minolta Bizhub 222 Black and White...
How to reset the default network settings
Do you know the current settings? If so, log into it and set it up. There should be a setting within the web page to restore to factory defaults. I don't know if this is something that can be done without logging into it.
Apr 22, 2011 | Dell 1700n Laser Printer
Can the copy setting be defaulted to black and white document?
You can set it to B+W but it will revert to its default setting the next time you print.
Jun 30, 2009 | Lexmark X1150 All-In-One InkJet Printer
Will only print in colour although the black is at 75% This is the 2nd time this has happened. Why?
the printer setting on many printers are set (by default) to print everything in color. change the setting to print only in black and white when you wish to print things in black only. HOPE THIS HELPS.......
Jun 15, 2009 | Office Equipment & Supplies
No setting for black and white printing only
The setting isn't on your printer, its in windows.
The next time you print, instead of just clicking "Ok" to send the document to the printer, click "properties." this will look different depending on your OS and whether or not you have printer software installed so I can't give you step by steps but there should be an option here to either set the printing defaults to greyscale or just a straight up black/white dropdown/checkbox. save that as default and you are done.
Jun 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Unable to print only in black without yellow in.
from the Printer Dialog box, choose properties and change the Default setting that is either Automatic or Colour to Black. Good luck
Apr 29, 2009 | HP Photosmart C7180 All-In-One InkJet...
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
42 people viewed this question
old marine
old marine
Corne Viljoen
