CL error code. what does it mean? - Washing Machines
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds. If this doesn't work then try pressing "options & select" till the light goes off. Also try and press ECO and rapid buttons together for more than 10 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
  • Evbrown Jan 25, 2011
    Its s button on the top row called Control Lock with a lock symbol on it. Hold that for ten seconds and your problem is resolved.
Error code cl
LG Washer Error Code Cl Fix. CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it
May 02, 2017 | Washing Machines
Getting error code CL. What does that mean and what to I do?
Generally CL means child lock. Turn on/off by holding in a button for 3-5 seconds. Lock for lock or key symbol or child lock label.
Jan 01, 2017 | Washing Machines
How to repair error codes on meistergram pro 1500 embroidery machine
Are you asking what an Error Code means and then how to fix the cause?
Error Information...
In case of incorrect operation or machine malfunction, the screen will display the
description of error or icons to inform you.
CL key [CL] Clearing...
This key is used for clearing errors, information or data such as stitch count and frame
coordinates.
Error codes are in the Single Manual (final) pages 68 thru 73
Download this manual's .pdf file...:
http://www.pantograms.com/images/meistergram/Meistergram_Single_Manual_Final.pdf
Feb 08, 2015 | Sewing Machines
What the CL code?
The "CL" code is not an error, it means the "Child Lock" is engaged.
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
Nov 06, 2012 | Washing Machines
What is the error code CL mean for LG WM1285FHD
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Thanks
Oct 10, 2011 | LG WM-2277HW Front Load Washer
On an LG front loading washing machine, what does the code CL mean?
Hi Emma Haigh,
CL means Child Lock, please follow my below Tip on how to remove the setting:
L.G CL ERROR/CODE
Kind Regards
JEDMEYER1
* If you found this solution helpful, please rate it
Aug 01, 2011 | LG Washing Machines
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
Aug 04, 2008 | LG WM-2277HW Front Load Washer
LG WM-1285FHD Error Code 'CL'
The "CL" code is not an error! This means "Child Lock"!
And happy day will come! :))
Apr 09, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
