Question about Cambridge Audio Azur 540D DVD Player
Dear Cambridge Support, I have Cambridge Audio
Dear Cambridge Support, I have Cambridge Audio Azur 540R v.3.0 AV Receiver and Cambridge Audio Azur 540D v.2.0 DVD Player. Audio system is Bose Acoustimass 15 Home Theater 5.1 system. LCD TV Samsung LE46" Problem: The Reveiver don't accept Dts 5.1 audio, only PCM audio ? When play Music DVD, I believe the Dts 5.1 will give the best sound. Audio connection: DVD - LCD TV: HDMI DVD - AV Receiver: Optical digital Settings: AV Receiver Input Setup: DVD Digital DVD Audio Setup: SPDIF Output: PCM Stereo LPCM Out: 96kHz HDMI Audio: PCM Stereo Hope this information helps solvong my problem. What's the best setup to deliver the best possible sound to my Bose speaker system ? Thanks in advance, Cheers, // Kjell Magnusson, Sweden.
SOURCE: Remote control codes
try this site www.satcure.co.uk i have got codes for my sky remote on it
Posted on Oct 22, 2007
marsrover
  • 682 Answers
SOURCE: Cambridge Audio Azur 640P
best connection from pre-out to aux in.
Posted on Jul 15, 2008
SOURCE: Speaker Connection
Put teh wire of the cable in the side of the plugs once you have untwisted them - they dont come out.
Posted on Jul 21, 2008
Grubhead
  • 5362 Answers
SOURCE: Cambridge Audio Azur 340A amplifier,no sound
Start with the basics first. 1. With the amp on, in each imput socket plug a dual end phono cable in and touch the right and left plugs with your finger. You should get a buzz on each speaker. No buzz and the channel at that terminal is not working. If none of the terminals buzz. Then the amp is dead.
If some buzz and others not you have a pre-amp problem.
2: Amp Dead. Could be A power supply. B main pre-amp. C Power Amp.
The power supply check for a fuse.
The main pre-amp will only effect both channels if an IC controls both.
The Power Amp will again only loose both channels generally if it is an IC. It will be attached to a big heat sink and have lots of pins comming from it.
If it uses transistors for the main amp, you can check these with an Ohm meter. With the power off place the leads on each terminal of each transistor. If the meter goes fully over (like when you touch the leads together) each way it has shorted.
The thing to remember when repairing stereo amps. Is that the amp is two identical amps joined together. So what happens one side will happen on the other. If both channels don't work look for something that is common to both.
Good luck
PS never heard of 'cliperd'.
Posted on Sep 25, 2009
SOURCE: Cambridge audio DVD 89. No more picture on my TV
Solution posted by pacarym worked for me.
Posted on Jul 23, 2010
Cambridge azur 540r receiver just stopped working. no power showing to on/off led.
Could have a problem in the power supply section. Check for open diodes and bad capacitors.
Sep 27, 2015 | Cambridge Audio Azur 540R Receiver
Cambridge azur 650R shows "PROTECT" after Volume more than 1/4, protection-relay works, loudspeakers&cable are o.k, WHY?/Solution (relay broken)?
What ohm rating does the receiver have and what ohm speakers are you connecting. If the receiver is rated for 8 ohm speakers and you are connecting 4 ohm speakers, you are overdriving the amplifier. This will cause the protection to trip. Also make sure your speakers polarity are matched. If they are out of phase this may also cause a problem.
May 28, 2014 | Cambridge Audio Azur 650r 7.1 Hdmi 1.3b...
Cambridge Audio Azur 640R AV Recorder won't switch off
Sounds like the unit is victim of a power surge. The power control board is probably damaged. You will be better off replacing the amp as having it repaired will cost more than replacing it.
Mar 02, 2014 | Cambridge Audio Azur 640R 7.1 Channel...
I have a cambridge audio Azure 540R. WAs all working fine. A red box with SW under the L speaker channel has appeared. No sound from the L speaker, Although the test sound through the L channel is ok. The...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Cambridge-Audio-540R-Receivers-review-manual/id/2536dj197/t/1-2/
"SW" stands for SubWoofer.
Page 8...
Shows the currently active channels depending on decoding mode and source material. Icons lit indicate active channels in the source material. Icons with a box around them indicate actual channels being output separately.
Search for the word "balance". Page 8 again (circled 8)...
Lights when the Front Left and Right speaker outputs have been set to different levels in the OSD, i.e. a balance adjustment has been made.
You can look at the relative levels of all channels as described on Page 14.
Mar 22, 2011 | Cambridge Audio Azur 540R Receiver
Very loud noise coming from amp as soon as amp is turned on..noise will not fluctuate with the volume..noise stays constant?
This will be the large Electrolytic Capacitors in the Power Supply. You can't miss them. They will over 4700uf or around that in value. Replace them all, even if only one has gone. I think what your hearing is the 50/HZ hum from the mains getting in.
Jan 12, 2011 | Cambridge Audio Azur 540R Amplifier
Protection overload and the system shuts off
Reasons: 1. Short in the wire, speaker, or amplifier 2. Amplifier malfunction 3. Overload of the amplifier 4. Overload of the speaker
Listening to audio at loud levels requires more power obviously. But the speakers and amplifier may not be rated or capable to handle it due to age or design.
Jan 13, 2010 | Cambridge Audio Azur 540R Receiver
check your speaker wires for short, try to turn it on without speakers connected, if all connections and speakers seem ok the problem is internal witch can go from blown power supply to shorted output devices and everything in between , and as always look for repair shop in your area, do not attempt to do it yourself, fire hazard and electric shock are the things we all want to avoid ;)
Sep 02, 2009 | Cambridge Audio Azur 540R Receiver
When put in stero mode,the speakers blast out at full volume..
I had the same problem and have solved it bij resetting it.
Try the small hole above the powerswitch.
Good luck.
Oct 30, 2008 | Cambridge Audio Azur 540R Receiver
Cambridge Audio Azur 540D DVD Player Logo
100 people viewed this question
Top Cambridge Audio Televison & Video Experts
Are you a Cambridge Audio Televison and Video Expert? Answer questions, earn points and help others
