Question about Samsung WF203ANW Front Load Washer
I have got Samsung big wash q1233, I have completed my washing but the door refuse to open. What can I do pls?
SOURCE: samsung washing machine reset code
solved this problem in 1 min lol just push the door in a little wen u press start so it can form an airlock
Posted on Aug 26, 2008
  • 21 Answers
SOURCE: Front loader door will not open after a washing cycle is finished
call the repair man it is a comp. issue
Posted on Feb 14, 2009
  • 14 Answers
SOURCE: Samsung J1455AV: Washing cycle does not complete and then stops
go back to where you bought it and have the engineer look at it might have been faulty when bought.
Posted on Jul 07, 2009
SOURCE: Keeps flashing SE
I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
Posted on Nov 26, 2010
  • 298 Answers
SOURCE: Samsung washing machine- error
you can try to reset it by unpluging it for about 15-20 mins to let it reset itself.
Posted on Dec 15, 2010
Gunge in door seal samsung Q1233 washing machine
It's caused by using too much soap powder or fabric conditioner,it doesn't get rinsed away properly and goes greasy & slimy,,,,,if its starting too smell change door seal,,,,,use bicarbonate of soda 1 or 2 times a month, no clothes or detergent,& on a 90 degree wash,,,that should stop it returning
Jun 19, 2013 | Washing Machines
I have a front louder newer model samsung washing machine. The door was forced opened during cycle and now the lock is still in the locked position and I cannot reclose the door or get the locked to unlock...
The machine has to reset to bringg tthe lock to release, check the link to the lock settings to make the program complete the cycle and release the lock. Do not force it as you end up damaging.
Sep 01, 2010 | Samsung WF206ANS Front Load Washer
The loading door gasket-- the big rubber liner doesn't drain
Some front loaders have a door boot drain hole, most do not and it is normal for some water to accumulate at bottom of boot. To help with mold and mildew use a washing machine cleaning solution, follow directions. Also a bleach solution of 2 parts water 1 part bleach sprayed on area helps. If mildew is really bad, nothing will completly remove it. Make sure you use only a high efficiency detergent.
Feb 03, 2010 | Washing Machines
E8 error code
8E - OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
Spin cycle complete; door refuses to open
check if the water has completely emptied - maybe the filter needs clearing.
otherwise. switch off mains. take top off. feel down the front of the machine to the door lock. you can usually find the peg and operate it with thumb nail but difficult
i assume you have'nt broken the door handle
Sep 18, 2008 | Belling SGE12X Front Load Washer / Dryer
Repair of samsung (karisma ) washing machine
Water draining is indicative that the drain valve is left open allowing water to escape even during regular/wash cycle and not only on drain/wash cycle completion. this could be brought about by:
1. laundry material, debris, safety pin, clips or some other foreign material has lodged itself prohibiting the drain valve in closing properly; or
2. the mechanism (solenoid) closing the valve is jammed in the open position.
Corrective measure calls for inspection and possibly cleaning or solenoid/control mechanism repair or replacement. Often these can be found at the bottom or near bottom of the machine below the tub.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 21, 2008 | Washing Machines
Door Error
Hiya... how long are you waiting? there is a timer door delay.. on nearly all washers now... usually around 2-5 mins!... Wait a few mins and see if this cures the prob.
Regards Faggly
Mar 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Dec 23, 2007 | Zanussi FJS1225W Front Load Washer
Samsung WF203ANW Front Load Washer Logo
70 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
