Unit easily heats up - Heating & Cooling
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 29, 2010
I had the thermostat , disc contraption out and heated thermostat sensor , seems to work good ,but still won't heat the water exiting unit
the most common problem with these heaters not starting is the pressure switch. you can easily bypass to test it but under no circumstances allow the unit to run with it bypassed.
Jun 18, 2014 | Hayward H Series Pool & Spa Heater 400k...
My corona air conditioner inverter does not produce hot air
these are all in one units, some of them are made like smaller central units and some of these are separate ac and heat units. the heat in the separate ones is run off of a heat strip in the unit it's self the ones that are made like a central unit reverse the flow of the freon in the system to draw the heat from outside. this is not something you can repair very easily yourself. most places require because of the freon that you have a certified HVAC technician to work on them.
Feb 22, 2013 | Heating & Cooling
Where do i see the fusing unit thermistor,thermoswitch &heaterlamp
I do not know which model of copier / printer you have, but generally the fusion units are on the sides of the machines, covered with a lid that can be opened easily, can be easily identified by the labels of caution have to be very hot.
The thermistors, heater lamp and thermoswitches are components that make up the fusing unit, the lamp is in charge of heating rollers, thermistors regulate temperature and thermoswitches turn on and off according to heat in the fuser.
They can sell separately or sell the whole unit, it will depend on the suppliers and the model of your printer or copier.
Good luck ...
Feb 27, 2012 | Office Equipment & Supplies
We have had our delongi dw47s/w diswasher for 2.5 years now, when we first got it in the first week we had an error 4, this was fixed under warrenty, now warrenty has run out we are now getting a n error 3...
This seems related to the heating sensor or the element both of which can be easily checked out., You need a multimeter in OHMS range to check the continuity of the element , if open the element must be changed. If the heating element works then the wash must heat if not there is no supply from the program controller unit. If there is no control of heat then the sensor also must be checked.
You can do this carefully by disconnecting the mains power and checking using a multimeter.
Aug 17, 2011 | Dishwashers
I have baseboard electric heat. My units are 27 years old. I'd like to replace with more efficient units but can't find any comparitive data.
Hummm, well, the newer units are trying to meet or exceed energy standards, so good on you for updating. You can look at Consumer Reports data to see which is best, but this method of heat does not lend itself to the same refinements as a gas furnace, for example.
I prefer units that have oil, or fans. The oil filled gives heat without having the heating element energized.
The fan units heat the room much better, but this is often NOT an option on baseboards, as many are wall cavity types.
220 volt costs less to run than 110 volt models, but this also is not something easily changed at this stage....
Oct 13, 2010 | Heating & Cooling
Dryer starts (heat on) after 5-8 minutes heating cycle stops and only cool air run through.
your heating element need to be cleaned.......
1. pull the unit out from the wall
2. Remove the screws holding on the larger rear panel.
3. Using a vacume cleaner extension, remove as much debris as possible from all accessible components.
4. Clean out the dryer vent and the connection to the wall, making sure that air can pass easily.
THAT SHOULD DO YA. If the heat continues to cut off, you are dealing with a faulty heating element in which case you will be best off to purchase a new dryer. (replacing a heating element is typically the beginning of a failing unit)
GOOD LUCK AND PLS RATE THIS POST!!!
Jun 03, 2010 | Kenmore Dryers
We have a split level home. The heating system is steam/boiler heat. There are three thermostats that control the heat on the different levels. The thermostats on the top floors are set at 68 sometimes...
JUST A REFERENCE; Unit designed to heat 900 sqft. 300 sqft per thermostat. When heat comes on and only 1 zone is calling the unit doesn't heat 1/3. It heats the 900sqft it's designed to. Therefore that "extra heat" HAS TO go somewhere. If it doesnt go to the "non calling" zones the unit would shut down on safety because it would get too hot. So, open a window or you need a bypass damper with bypass duct installed that when the heat comes on for only one zone that "bypass" opens and sends the "extra heat" back into the return rather than to the "non calling" zones. To answer your question, nothing is wrong with your unit or tstats, it's the duct work. Maybe $600 to $800
Jun 05, 2017 | Heating & Cooling
Dyrer won't heat...how do you get to the heating unit?
Take 2 screws out the bottom of the front panel and yank the panel off from the front.The fuse,highlimit and heater are all easily accessed on the bottom rear left hand side. All you need to do is remove two hexhead screws and the heating assembly comes right out.
Jan 20, 2009 | Speed Queen AES28AWF Electric Dryer
Need to Replace Heat ELements
you remove the screws that hold on the base plate that has the sequencers mounted on it. pulling it out so the elements clear the sides of the unit. once you remove it you can easily see the heating element coils which you can purchase a restring kit fairly cheap at your local appliance parts store. just remember to stretch it out uniformally the same length as the old one, reinstall the heat kit the same way you removed it. kit comes with new ceramic gromets if some are damaged. these units do have a 5 yr warranty on the heat strips.
Jan 12, 2009 | Ruud UBHC Air Conditioner
Maytag Atlantis dryer no heat
The heating element and thermostat are located behind the front panel of the dryer. you will need to remove the door, then the retaining screws. the heater / element is located on the left side as you are facing the front of the dryer and has to sheet meta screws (upper back top / and front bottom) which will need to be removed. the unit has several colored wires for the thermostat and switch. remove these (remember which goes where) and the enitre unit will come out easily.
Aug 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
