Question about Dell Microsoft Windows XP Home Edition
My computer shuts down to sign on every time I leave it idle for more than 10 minutes I have tosign on again and again?
  • 43 Answers
Right click on desktop
click on the screen saver tab
click on power
you will see option for the power management select the appropriate one
Posted on Aug 29, 2010
Issues after cattery change.
Not without plugging it in and seeing what codes pop up ,as for the door locks then try disconnecting the battery leaving for a few hours then trying again ,failing which try unlocking and locking the door three times and see if this will reset it
Apr 27, 2014 | 2002 Mitsubishi Lancer
Truck shuts off
Sounds like a fuel sensor either fuel pressure tank pressure or a bad fuel pump either way it seems your fuel pump is shutting down. It could also be related to the security system scan the vehicle for sensor codes or security faults also if the ignition key is worn it could cause the computer to read it as a bump key and activate the anti theft system
Apr 11, 2014 | 2000 Toyota Tundra
Kenmore series 90 washer runs for a short period and then stops
Sorry to be the bearer of bad news but what your describing is a classis sign of a bad motor. When the motor is bad it will run will its cool...when it heats up it shuts off and will restart for a short time when colled off till once again hot and shuts off again.
GENE
Oct 29, 2011 | Washing Machines
I have a Gateway GT5654 desktop that won't stop shutting down. I bought the computer brand new about 3 years ago, and I've never had any problems until now (I've even been running Norton 360...
it is possible that one of the three are going out on the computer, motherboard, harddrive, power supply, only a computer tech could tell which one.
Sep 21, 2011 | Gateway GT5654 Desktop PC
My 2002 GC 4wd automatic trans 4.0 engine shuts down only when the outside air temp is above 80 degrees. When approaching a red light / stop sign, I let off the gas pedal and at times it will shut down...
If a dealer can not fix it, we can't guess at the unknown
Now your involved with a dealer leave it there, until
they solve it. Somebody has to stay with it, to a successfull
conclusion.
You could ask around about repair shops that are good at
diagnostics & drivability issues
Apr 25, 2011 | 2002 Jeep Grand Cherokee
Fast idle wont kick down. it has to be shut off and restarted 2or 3 times. before it will kick down
I believe you will find that your idle air control valve needs to be replaced. This is located on the Throttle body. After replacing the idle air control valve, make sure you disconnect the battery ( either the negative or positive cable ) and leave disconnected for atleast 10 minutes. Then reconnect and start vehicle, your car may fast idle for a short period of time before it returns to idle so is so your ecu relearns the correct postion and resistance reading
Oct 11, 2009 | 1999 Chevrolet Lumina
Car will start fine but will shut off as soon as I place in gear.
Here are the most common causes of surges, stalls at stops, low erratic idle speed, rough idle and engine hesitation, it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Mar 30, 2009 | 1991 Chevrolet Cavalier
Computers & Internet Logo
21 people viewed this question
Alun Cox
