Question about Hotpoint Washing Machines
Comfort does not drian out of draw - Hotpoint Washing Machines
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Aug 29, 2010
What are the benefits of leather gun hostler?
Holsters are very important for all officers for their off-duty time. So if they are having leather concealed carry holsters they will get many benefits such as
1. They can easily draw their gun
2. It can be worn on the strong side or cross draw.
3. This holster is perfect for haunting and pasturing.
4. It keeps your gun from flopping out.
Mar 14, 2018 | Air Tools & Compressors
How should I choose my Bow Draw Weight?
Make archery fun. Choose a bow draw weight that is comfortable, less than what you are capable of pulling. Many new archers become discouraged and quickly lose interest in the sport when the bow is so heavy that it is not fun to shoot, or when the bow is so heavy that accuracy is lost. Most states have a legal weight of 40-50 lbs
Jul 09, 2012 | Archery
Battery keeps drianing alternator test good but have a short in the engine ignitin feed
Even though the alternator tested good it still may be your problem. Unhook the alternator power wire and let the car set for the amount of time it usually takes to run down the battery. If it starts right up, you've found your problem. If that doesn't help, sometimes a relay can stick and cause a draw on the battery. You might try the same thing with the relays, pull them out and let it set. Replace them and see if it starts.
Apr 21, 2011 | 1996 Plymouth Neon
The battary keeps drianing max one day then the battary goes flat
Either your battery itself is to blame, or you have something that's drawing power even when the car is not running. You can disconnect the battery overnight, then reconnect it in the morning to see which problem you have (i.e., if the car starts, your problem is a power draw; if not, it's the battery). Your best bet though it to have an auto shop test the battery for you.
Bill B.
Aug 24, 2010 | Mercedes-Benz C230 Cars & Trucks
My Kenmore elite 40512900 stays at 7 minutes
well often when it hits the last ten min of a cycle it is trying to drian more times then not it isnt or it hasnt senced it has drianed so odds are that your drian pump not drianing or you have a bad pressure switch. i would start with the drain pump often it has a filter that get clogged and can be gottin to from the front
Jun 02, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore washing machine that stopped working while washing a king size comforter. It looks likt the comfortor may have got caught on the agitator. I can hear a sound coming from the motor area...
The comforter is too big for these washers. But it sounds like you may have taken out the motor coupler. It's an easy fix. If that's not it, then the transmission broke. But it is more than likely the coupler.
Dec 30, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore 70 series 110.24712300 washer that wont drain? I had just wsshed a rug in it that lost alot of its "fluff" Do you know what may be the problem, the drian pipe is clear. Thanks
The fluff may be stuck in the propeller; you'll have to disassemble the machine down to the propeller to inspect/clean it
Go to this link and enter your model number, it will provide you with exploded view drawings of your unit to help you with the disassembly
http://www.searspartsdirect.com/partsdirect/index.action
Nov 16, 2009 | Kenmore 24032\24036 Top Load Washer
Powder and comfort not going throught properly/always some left in the draw
hi there....remove and clean soap dispenser drawer....paying particular attention to the area beneathe the drawer....cut down on the amount of detergent and comfort you are using
regards Sir Galahad
Aug 21, 2009 | Tecnik TKL9260 Front Load Washer
I have a 2001 2.8 v6 galaxy that will drian the battery flat in a couple of days, any help on this would be helpfull.
lets say you have had the battery tested and it's ok?
(as bad batteries do hold charge but only for a short time)
the fluid inside the battery is at the correct level?
when u start the car you should be able to disconnect a battery lead and the car should keep running, (alternator test)
if everything checks out so far?... use an amp meter across the fuse terminals to see what is drawing excessive power.
Its a process of elimination. always start at the simplest part and work through.
Apr 13, 2009 | 2001 Volkswagen Passat
Washing Machines Logo
51 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
