Question about Nokia 6310i
My 6310 won't turn on or charge, i plugged it in for aproximatly 15 hours, i press the on button and it still just Flashes "not Charging! " a few times it's given me hope, by turning to the mainscreen, it then says battery empty, and turns off again. Please help me? should i get a new battery?
deepakonly
  • 87 Answers
SOURCE: Phone will not turn on
there is problem inside ur phone for which is causing "local mode" u should take it to technician.
Posted on Feb 22, 2008
270rexton
  • 782 Answers
SOURCE: nokia 5800 wont charge?
Use different charger. When charging leave the phone off. Fully charged after 4 hours.
Posted on Jun 10, 2009
JAN_yuanjia
  • 470 Answers
SOURCE: not charging phone
car problem is the MALWARE problem of the mobile, you need to reprogram your fon
Posted on Mar 05, 2010
  • 1417 Answers
SOURCE: Nokia e63 won't switch on or charge
hello,
this have nothing to do with your phone battery and the phone charger
from your statement what you need to do to fix up the problem is that you have to make a change of your phone charging port this is well the problem is from
the charging port bad
dole it will give a sign that it charging but the same time it will discharge the power and this can cause a damage on the battery bass on constant charging
what you need to do is that you are to make a change or replace the port with a better one
if you can not do the fix up your self then you will have to take it to a very good phone work shop around you to do the fixing then your phone will work fine again
thank you .
Posted on May 01, 2010
SOURCE: My Nokia X6 won't turn
crash firmwire or crash powersupply
Posted on Feb 19, 2011
Won't take a charge.
Armend, Could be a bad charging port. Press and hold on button for 15-20 seconds a couple times to see if it will reset and power up before trying anything else. Check the attached links, videos,instruction and guides on kindle charging problems. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kindle Fire Won Charge Fix
12 major Kindle Fire problems and how to fix them
Reset Kindle Fire When it Won Turn on or Charge
Apr 08, 2016 | Amazon Kindle Fire HD
Will not turn on, and will not charge, totally dead
Or if all you get is a green light when its plugged into an external charger, then you could have blown one of two Microchips on the charging circuit and to get it working again they will have to be replaced. If it has just become corrupt you can try resetting the tomtom
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for at least 15 to 20 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Exact location of reset hole is in the picture below
Aug 09, 2011 | Tomtom GO 300 GPS Receiver
My battery for canon camera 550d flashes orange when charging, its been 4 hours now and it hasnt turned green yet.. I am charging it first time.. is this normal
Okay what happens sometimes is the charger gets into a feed back loop. What to do is remove the battery unplug the charger wait a few seconds (Maybe 20/30) plug the charger back into the outlet and then put the battery back in the charger. It should start to charge again and a few minutes later go to the blinking for full charge green.
It'll happen the other way as well meaning if the battery gets a memory (they say they don't but they do) you need to unplug the battery let is sit till it's cool and put it back on charge again. I've had this problem many times and have put it on charge and back off several times with in 15 minutes before it started to charge as it should.
Also these batteries do have a life span and if it's a three year old battery with many charges it could be failing meaning it just won't take a full charge.
Apr 19, 2011 | Canon Cameras
MY GARMIN WON'T TURN ON WHAT CAN I DO
first of all, leave it charging for 2-3hrs.
take the SD card out if you have it inside
try then to turn it on
if nothing happens - then press reset button on the bottom side of device (hidden behind plastic sticker, but marked)
then try again to turn it on
if nothing happens - take it to authorized service center
Aug 19, 2009 | Garmin nuvi 250W GPS Receiver
TomTom One shows a green charging light but when the button is pressed it fails to turn on
try the hard reset first (hold the reset for about 15 seconds..its the little pin hole on the bottom) if that fails, plug it in to your computer for a few hours via the usb cable, then try again. if that fails, download tomtom home if you haven't already and connect to tomtom home
Aug 19, 2009 | GPS
I Can`t switch my headset on, and it stops charging after 20 secs
Move the call control button up or down, the indicator light will flash blue if it's paired or blue and red. If it flashes blue and red you need to pair phone with the headset. the passkey is 0000.
Jun 17, 2009 | Plantronics Explorer 340 Wireless Headset
Samsung YP-U3 mp3 won't turn on!! help please
try pressing the menu button and the play button at the same time
Jan 13, 2009 | Samsung YP-U3 MP3 Player
Bluetooth headset
USING THE HEADSET
US USING THE HEADSET
1. Headset
2. Control Button
3. Light Indicator
4. Microphone
5. Earloop
6. Speaker
7. Charging Jack
A. Charging
Charge for at least 20 minutes before
first use. Complete charging in 2 hours.
Headset will not function when charging.
B. On/Off, Volume↑↓
Press the Control Button for 2 seconds
to power on. Press the Control Button
for 3 seconds to power off.
C. Pairing
Begin with Headset turned off.
Press button for 6 seconds. Release
button when Light Indicator flashes
blue/red. Headset is ready to pair with
Bluetooth device.
D. Pairing
Use your device’s menu to begin
pairing mode and select “320
Plantronics” on the display. When
asked for passkey, enter “0000.”
Jul 13, 2008 | Plantronics Explorer 320 Wireless Headset
Nokia 6310i Logo
334 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
