Question about Sony Cineza VPL HS2 Multimedia Projector
I have a Sony vpl-1 projector that on initial start up it shuts itself off We have to keep cutting the power completely and start it again, this we have to do for around 4 or 5 times before it works properly. I have had a message that the lense cover is on but it is not. Any ideas please ?
If the projector has a lens cap, you have to help the projector to open it completely. Just use your finger and push the cap all ther way. On the projector I have this vis the case. there is a micro switch at the end og the lens cap opening mechanism.
gunnar.gronlund@nrk.no
Posted on Dec 10, 2010
Projector starts the goes off by itself.
Check the fan is working could be shutting down cause overheat
Oct 16, 2012 | Sony VPL-ES7 LCD Projector
I have a VPL-CX70 that has a new lamp (less than 50 hours) and the hours were reset to 0 when the new one was installed. However, today, the lamp cover LED started blinking and the projector shut itself...
The bulb is not lighting correctly.
Take out the bulb and check the connectors are not dirty and reinsert.
See if you can see the bulb looks ok, you may be unlucky that the bulb has prematurely failed (hope not)
Try again to start it.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | Sony VPL-CX70 Multimedia Projector
Sony VPL HS 1 will not start after a power cut, fuse ok, including first stage fuse inside unit. standby light not on ..any ideas?
Try cleaning out the filter. There may be a heat protection mechanism in there. We had much less problems after cleaning (or replacing the dust filter).
Feb 23, 2010 | Sony VPL HS1 Multimedia Projector
Sony projector
clean the air filters of your projector.. if problem still the lamp ballast of your unit was defective.
Oct 23, 2009 | Sony VPL CS3 Multimedia Projector
How to disable power on password on Sony VPL-ES2 LCD projector?
Hi there! I'm assuming you're able to enter the password so that the unit comes up...Go into the menu selection called "Initial Settings". Choose the option called "Security Lock" and pick the "off" menu item. Exit out of the menu and power down the projector. Re-start the projector and it should have no password activation. If you need the user manual, let me know...Hope I assisted you successfully!--Rick
Sep 09, 2009 | Sony VPL-ES2 LCD Projector
Sony VPL-CX6 Projector turns itself off. No image projected.
does the "lamp/cover"-led light up? i had the same thing happening, the lamp either broke or is about to break and the projektor won't turn it on again to protect itself. if its very urgent, open the projector pull the lamp out and put it in again, it might work for 1 or 2 more times, but it is very likely to explode (usually not breaking the projector but for sure not good for it).
good luck!
Jun 26, 2009 | Sony VPL-CX6 Multimedia Projector
VPL-EX1 Just bought it from someone the lamp is 450 hours, it worked fine with no message. no im trying to turn it on and it will just lift itself and lamp cover moves but then nothing happens and after a...
I have had the same problem with 3 Sony VPL-EX1s and Sony will not answer emails regarding the problem. Hence I wont be purchasing Sony projectors again.
Apr 01, 2009 | Sony VPL-EX1 Multimedia Projector
Sony VPL-DS100
I have solved this problem. Seems the rotating stand on the front bottom needed to be pushed and turned so that it inserts well inside. If it not well pushed the projector keeps shutting down itself every 10-15seconds. Took me about an hour to open the projector and doing all kinds of experiments to finally try that. :)
Jul 06, 2008 | Sony VPL-DS100 Multimedia Projector
Sony Cineza VPL HS2 Multimedia Projector Logo
137 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
