Question about Samsung LA32A450 32 in. HD-Ready LCD TV
I have Samsung LA32A450 32 inch HDML LCD when I switch it on the red eye light turns on but when try to on it with remote or otherwise the picture is not shown. Pl. advise the solution or the root of problem.
  • arunkhanna20 Aug 29, 2010
    Thanks,there is no sound and no picture.The power was switched off but not unplugged .Should I unplug it? Secondly ,how to verify the protect mode due to a surge?
  • 4,889 Answers
Do you have sound or no sound and no picture? Did you verify whether the set has gone into protect mode due to a surge? Try unplugging the set and wait for 5 minutes before plugging it back in. See if it comes back on and let me know.
Sai.
Posted on Aug 29, 2010
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 158 Answers
No image then T-con board defective.
Posted on Aug 21, 2015
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Televison & Video
My Samsung LCD TV (40A450) 40 inch, when switch turn on after 2-5 second it turn off, no red light. when i remote to switch on then the red light is on and then press on again the lcd tv on after 2-5...
The capitors on the back might be bad this I have fixed on these tv's many times. That could be one of the problems and the capitors are on the power board inside the tv. If you do not know how to work on electronics I would have a pro do it they contain hight voltage so be careful if you try to fix it yourself.thanks
Oct 06, 2010 | Samsung LA40A450 40 in. LCD TV
On/off switch Samsung 42'' Model 530 LCD
probably caused by the power supply board beginning to fail. eventually it will not come on at all.can call 1-800-samsung for nearest service center.VERY common problem.
Dec 30, 2009 | Televison & Video
TV doesn't turn on, three lights (blue, red, red) goes thru the normal start up, but stops with red lamp light on.
my samsung lcd 40 inches.power on blink contineoisly when we switch on LCD KIND GIVE SUGESTIONS
THANK U
BAKSHI
vkb3@rediffmail.com
Nov 14, 2009 | Hitachi 50VG825 50 in. LCD HDTV
Wont turn on
The power supply board has been defected. Replace it with a new one.
Aug 15, 2009 | Samsung LN32A330 32 in. LCD TV
Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Samsung LA32A450 32 in. HD-Ready LCD TV Logo
480 people viewed this question
Henry  Thomas
Henry Thomas
