On SM 331 Card, SF LED (Steady) comes. For that I have replaced the module with spare one but problem is still persisting. Also download the program. But no improvement is found, In diagnostic buffer it is showing Module Faulty (Interrput Diagnostic detected) even after replacing new module. Pl. help
  • 1527 Answers
SOURCE: I have a Frigidaire LTF2140ES1
hello doug just looked a error code e43 board communication problem
shaun
Posted on Jan 16, 2009
gpgab97
  • 77 Answers
SOURCE: Faulty Fuel Pressure Regulator
I would make the repair if the need is urgent enough to warrant the 650 but i would most definitely try to get a better quote on labor. This is a one man job that takes me about an hour and a half to do once im all set up. If you can find a local "wrench" in the classifieds, or even try a quote from a towing company as they carry their own mechanics. I would charge about 230 in labor and pull the fuel rails and regulator off another car to save you money for a total around 425 dollars. Still, if you prefer your mechanic and you want new parts, a premium is to be paid. You also could sell the car at 1900 as is and still profit as well. Best of luck, Tony.
Posted on May 02, 2009
  • 85 Answers
SOURCE: I replaced air bag module on 2003 saab 9.3
only with tech2!
Posted on Aug 29, 2009
outdoorsman5
  • 631 Answers
SOURCE: I just read the diagnostic codes on my 1990
Code 34 has to do with your MAP sensor I believe from what I am reading. I don't know a lot about corvettes but it says MAP sensor voltage low. The C12 code I see is a normal code set dealing with no reference pulses being received by control module. In other words with the engine not running. It has to do with No RPM reference pulse.
Posted on Sep 09, 2009
sarasvatas
  • 329 Answers
SOURCE: Mouse left button click is highlighting several
try using USB mouse........
Posted on Oct 01, 2009
Try to program and it comes error L5
PAGE 63-64 in link Describe "LS" error.
7
Belts stop turning and "err
LS" or "err OS" is displayed
Calibration
Re-calibrate machine. (See Calibration Procedures, Pg 26)
SPEED
SENSOR
1. Cycle power off and on
2. Put the machine in calibration mode (see Calibration
procedures, Pg 26) but do not start the calibration routine.
3. Remove right rear base plastic cover to allow access to
LED board. Caution: Machine is on. Current is active!!
4. Locate LED D on the motor controller board. LED may
be lit or unlit.
5. Manually advance the treadle with your foot, and check
if LED D is blinking.
6. If LED D is not blinking, then the speed sensor is not sup
plying a signal. Check that the speed sensor is connected
securely to P1 on the motor controller. If sensor is con
nected and LED D still does not flash replace sensor.
I/O cables
If LED D is flashing when the belts are turning but err LS
or OS persists, check for signs of visible damage to any of
the three I/O calbes and connections. If no visible damage
check continuity using a multi-meter. If a multi-meter is
not available replace all three cables.
Electronics
If all I/O cables are functioning properly, LED D indicates
speed sensor is functioning, and err LS or OS persists
problem is in either the upper electronics board or the
motor controller board. With machine on check LED A
on the controller board. If it is dimly lit replace upper
electronics (000-4430). If it is not lit at all replace motor
controller.
http://download.nautilus.com/supportdocs/AM_OM/Bowflex/BFX_TC5300_6000_OM_AM_RevA_web.pdf
Jun 04, 2014 | Bowflex Treadclimber TC5300
Cannot get the card to work properly
JimmieReb,
Try formatting your original card in a PC - use FAT file system.
Then re-insert it into the Camera.
Feb 28, 2008 | Olympus Camedia C-740 Ultra Zoom Digital...
I came home from vacation and the red LED was steady on. I replaced the batteries, and reset the master code. Everything seems to work, but the red LED is still on steady. How do I turn this off?
I have reviewed the installation and programming literature for the DL 2700 and there is no mention of circumstances where the red LED should stay on. For your convenience, I am providing the web link to Alarm Lock, the manufacturer of Trilogy, where I find the installation and programming instructions:
http://www.alarmlock.com/tech_library_instruction_manuals.asp
These links on this tech support page are in the format of PDF files. If they don't open for you, you need to install Adobe Reader first. You can get the free download for Adobe Reader here:
http://get.adobe.com/reader/
Concerning your problem, I would expect that the constant-glowing LED may drain the batteries over time and prevent your lock from working. I urge you to give Alarm Lock a call at this number
800-252-5625 during regular business hours (East coast) and request Technical Assistance.
I hope you are able to resolve this quickly-and inexpensively!
Aug 07, 2011 | Trilogy Alarm Lock T2 TRILOGY Digital...
Dell Dimension 3000 will not power up. Solid amber lit stays on. Any help would be accepted.
  • If the power light is steady amber, a device might be malfunctioning or incorrectly installed.
    • Remove and then reinstall the memory modules.
    • Remove and then reinstall any cards.
    • Remove and then reinstall the graphics card, if applicable
Refer to the link: http://support.dell.com/support/edocs/systems/dim3000/en/SM/adtshoot.htm#wp1043338
Jan 26, 2011 | Dell Dimension 3000 PC Desktop
When i download the hw conf. in the plc im151 pn/dp after that plc mode is in stop and all modules sf led glowing(group error) Please tell me the solution
Re-check your hardware configuration.Make sure you correctly configured each slot ast to the type of hardware that is there. Make sure your program is not calling for a function (block transfer etc) to a module that isn't there.
Mar 09, 2010 | Siemens ENERGY & AUTOMATION W0404MB1200CT...
Computer on start up makes noise and the 3 & 4 and battery icon light up and nothing comes up on monitor.
The diagnostics codes that you have got indicate
Memory modules are detected, but a memory failure has occurred.
solution:
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, contact Dell (see your computer Owner's Manual for information about how to contact Dell).
Owners manual to help you reseat the memory modules
http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
Thanks for using Fixya
proton
Nov 09, 2009 | Dell Dimension E310 PC Desktop
Computer won't boot on start
sound like you have a bad mother board
Oct 09, 2008 | FIC Samba SM-1845 (SM1845GV) Barebone
Narly
  1. Clean cooling components that have become clogged with dust. If beeping persists, continue to the next step.
  2. Remove a memory module. If the PC stops beeping, the memory module may be bad, is the wrong type of memory for the motherboard, or was not fully seated/connected. Try reseating the memory into the socket to see if a connection was the problem, otherwise replace the module. Remove each memory module, replacing the one that was previously removed. Once all modules have been checked, if beeping persists, continue to the next step.
  3. If your computer has a graphics card, remove it. If the beep code changes or continues with the same beep pattern, the video card may still be good. reseat the video card into its socket and continue to the next step. If the beep code goes away, the video card may be bad. Try reseating the video card, making sure it is fully locked into the connector on the motherboard. If problems persist, replace the card.
  4. Remove a PCI card. If the beep code goes away, the card may be bad. Try reseating the card into its connector on the motherboard. If problems persist, replace the card. Remove each PCI card, replacing the one that was previously removed. Once all cards have been checked, if beeping persists, continue to the next step.
  5. Disconnect hard drives and CD/DVD drive cables (IDE/ATA) from the motherboard socket. If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems persist, the drive itself may be bad and may need to be replaced. Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. Once all connections have been checked, if beeping persists, continue to the next step.
  6. At this point, the problem probably involves the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case. Make sure jumpers are set correctly.
Jun 09, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
Monitor screen shows all sorts of colors in line patterns.
with the information I gathered IBM netvista does not features a video card, it is inbuilt. So it shares your system memory. just open the sysyetm chassis and take out the RAM module and clean the contact edge with a rubber eraser (pencil eraser). Re insert the RAM module and try again.
If the problem persists. try changing your memeory module(s).
Oct 28, 2007 | IBM NetVista PC Desktop
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
