Question about LG Televison & Video
Our LG TV model CT-29h32en twice a week will turn off to black screen with thick white line across the screen. We turn the set off and wait 5 minutes and turn back on and all is OK. If we turn back on immediately it returns to the black screen and white line. All with no sound.
  • ken2582 Aug 29, 2010
    Thanks for the clue. I will inform our repair man.
  • ken2582 Aug 30, 2010
    I will inform my technician...so he doesn't go round the long way, like some taxi drivers. lol
  • 4,889 Answers
You have faulty electrolytic caps on the main audio/video board. A component level repair might be possible. Do you have any prior experience in working on electronic circuits? Can you solder and/or use a multimeter(with capacitance measurement if visual identification of faulty caps is not possible)?
Posted on Aug 29, 2010
  • eagle338
    eagle338 Aug 29, 2010
    Sure. Please do accept the solution if you find my advice helpful.
    Sai.
  • LG Master
  • 11,800 Answers
That thick white line is the normal image that is squeezed vertically because the vertical deflection unit has stopped working.The only thing that the vertical deflection unit and the audio amplifier unit have in common is the power line - they are the only ones that use the 25 volts line so when that fails both units fail.
Since this is an intermittent fault that means that is caused by a bad contact - the tv must be opened, the 25 volts line identified and all solderings on it redone. Basic stuff - if you have done a soldering of before. If not, then you might do a lot of damage by accident so call a repairman, you will pay only for its labor since no parts are needed.
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Hi, I've purchased a 2nd hand LG 42" Plasma TV set
Usually black lines in a flat panel indicate an error or problem in the video board. A service professional can hook up to the tv and better diagnose the issue.
Mar 23, 2011 | LG Televison & Video
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
Line across middle of screen.
The line of color is due to a failure in the vertical circuit. The main suspects are the vertical Ic AN15525A and/or capacitor c308 220uf@35volts
If you have the capacity to do so, you should check the other electrolytic capacitors in the vertical circuit which are USUALLY located near the vertical IC in most cases
you can purchase the part at
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5760279&smodel=CT32SL15N
or mcm electronics
Mar 13, 2009 | Panasonic CT-32SL15 32" TV
Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
Oct 10, 2008 | Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
Televison & Video Logo
204 people viewed this question
Computer Repairing
Computer Repairing
