posted by 34m30 on May 07, 2008
I dropped my Compaq Armada and the screen is now too dim to be much use. Is there a dimmer adjustment for the screen and how do you access that?
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 22, 2008
I just want to replace the screen color of my Compaq armada e500, from dim to paper white screen. How can i make for adjustment?
Solution #1
posted on May 07, 2008
There is a dimmer function that is part of the keyboard on most notebooks. You use the Fn key and some other key (Mine is F1 and F1) Look for what looks like Sun in blue print on the key. You should find 2 of them. One will be the brightness up and the other brightness down. You can try those.
More likely, something has come loose internally.
1. It could be the backlight for the screen is broken or a connection loose. You should be able to see the light when you look at the side of the display.
2. The AC power connector may have been broken and the notebook is only on battery power. By default most systems are dimmer when on battery power. Check to see if your charge indicator light is on. If not, that may be the problem.
I hope this helps.
I hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Compaq Armada M700 PC Notebook
Email this problem
Email this problem
Can you Help with these PC Laptops problems?
compaq armada m700 wont boot up
everytime i try to boot up my... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
