Question about Arcam AVR-100 Receiver
Mhow do you connect bt vision box cd player to tv
  • Arcam Master
  • 11,800 Answers
You must use a standard AV cable - one with 3 RCA jacks:Yellow for Composite video, Red and White for audio.
Just plug them in the correct connectors - they should be close together on the back of the dvd and the tv, clearly labeled.
Posted on Aug 29, 2010
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Codes for tuning bt vision box to sanyo tv
Here are the codes:
First try the 4 digit ones:
0136, 0242, 0722, 0732.
Now try 3 digit ones:
106 154 155 156 157
160 208 210 216 267
275 282 316 319 320
322 360 0236, 154,182 ,190, 191, 220, 221, 278, 282, 283, 323.
Goodluck..
Feb 14, 2008 | Televison & Video
Why do's my bt vision box keeps rebooting its self
It sounds like it has a fault. Contact BT for a replacement.
It might be worth trying the following first: Restarting the BT Vision box Help BT com Help
Mar 03, 2014 | Apple Find My iPhone
How do you connect a fujitsu p42vca30eh to a BT Vision box? Which cables are needed? Thanks Emma
You should use a HDMI cable. This cable will carry the audio and video from your Vision box to your plasma screen. Connect the cable to the HDMI port on the vision box and the other end to HDMI 1 on your TV. Once that is done turn on the vision box and then the TV and switch the TV to HDMI 1 using your tv remote and then once you have a picture use your vision box remote to change channels and perform other functions. techpunk_0.jpgtechpunk.jpg
Mar 02, 2011 | Fujitsu Plasmavision P42VCA30EH 42 in....
Cant get my bt vision [freeview] to come on. my box doesnot let me view freeview . on my bt vision box.
This system can only be used if you subscribe to BT Vision.
They have it configured so that Freeview only works once the box has checked your subscription.
I think this is a bit mean of BT because with their system Freeview is not free as you cannot access it without paying the monthly fee.
Aug 27, 2009 | Philips Televison & Video
How do you connect bt vision to a sony bravia kdl 37v4000.I have it working ok on freeview only but the bt vision appears on analogue channel 6 and the vision remote changes the tele channel not the vision...
Sounds like you cant have set up the scart cables properly. Im unimpressed with BT for not setting it up for you, why didn't they?
Plus you will not need the freeview box if you have BT Vision, so i would take out the freeview box and just connect one end of the Scart lead into the back of the BT Vison box then put the other side of the lead to the Back of the TVs scart socket. Then all you need to do now if change the channel to AV1 OR AV2 or whatever channel you have.
Jul 23, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Remote control
the code for the bt.vision box remote to work a durabrand tv is under the emerson range the code i used was 004 it works fine
Oct 10, 2007 | Durabrand DU1901 TV
Arcam AVR-100 Receiver Logo
53 people viewed this question
Top Arcam Audio Players & Recorders Experts
 Grubhead
Grubhead
Sock Puppet
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
