Question about HP Photosmart 3210 All-In-One InkJet Printer
Printer cartridge problems
I have had my printer for a couple of years with no problems. Now when I install a new megenta cartridge, it feels like it isn't pushing all the way in the opening...it feels wobbley. I can shut and snap the little door shut, but the printer is not reading that the cartridge is in place and will not print. It says "service or repairs required as a result of using a non-HP supply..." but I've only used HP cartridges. Any ideas?
  • honkeyjuggal Aug 01, 2008
    It says Error at the top and under that it says Press OK to continue. When you press OK It says printing then device maintenance occuring-do not interrupt. It makes a lot of noise like its doing something then it stops making noise and says Press OK to continue. You can press it 100 times and it does the same thing over and over again.
  • 3 Answers
Try cleaning the peg that inserts into the ink cartridge. maybe it has dried ink build-up. only use distilled water and a foam q-tip.
Posted on May 23, 2008
I have a HP 8259 printer and it indicates the yellow print cartridge needs to be replaced even when i install a new cartridge. It will not let me print in color or black/grayscale. I have had the printer...
Older printers can do funny things. It is probable that the little copper contacts on the ink cartridge are not making good contact with the printer which is giving bad information to the computer that the ink cartridge is empty. A two year old printer may have some corrosion on the printer's contacts. Remove the ink cartridge and use a soft pencil eraser to clean the printer's contacts.
Oct 10, 2010 | Office Equipment & Supplies
There is a megenta vertical line in all my prints. Replaced all toner carts.
change the Magenta cartridge & try if the same problem then PCB damaged. Contact service center. Thanks.
Feb 18, 2010 | OKI C5200n Laser Printer
Magenta pin stripe on HP-CM4730 crossing the full length of page.
Replace the magenta cartridge or replace the plastic clear guide on underside of document feeder if happening using the document feeder
Jan 13, 2010 | HP LaserJet 4730 MFP Printer
Epsonr220 does not print megenta or light megenta colors
The problem seems to be the printhead nozzels are plugged or burntout. I beleive on the Epson, to remove the printhead for cleaning, you must partially disassemble the printer. If you are not up for this, Quit here. If you game, remove the cartridges and tape over the outlet and air hole of each. I find electrical tape the best. Tape snugly but not too tight and once around the cart. If you have a digital camera or a webcam, take photos along the way to help in re-assembly. Remove the drive belt and disconnect the guide rod the printhead slides on at each end. Try and remove the guide rod and print head as one unit. Use alcohol and/or water to clean the print head nozzels, or completely wash the print head with running water. Blow it off and let dry. Put the guide rod back in the print head and put that assembly back in the printer. Attach the guide rod at each end then put the belt back in place. Put the cartridges back and do a nozzel/print head check. If the printer works completely, then you are set. If the magenta still doesn't work, the nozzels may be burnt out. I don't think you can get Epson Print heads, That means a new printer. Lastly DO THIS AT YOUR OWN RISK. I can't even guarantee my work!
May 28, 2009 | Epson Stylus Photo R220 InkJet Printer
Since this morning my printer is not printing the red(megenta).
The problem is with the print head.
Firstly try cleaning cleaning and more cleaning because it means the nossles are blocked or the head is done for. If after doing a ridiculous amount of cleaning it still doesn't work then a last resort that has worked multiple times for me is to get a syringe without a needle. Remove the color in question and get a cup of boiling water fill the syringe and squirt it in the cradle where the ink gets fed to the head and wait 15 mins then repeat the process a few times. Wipe up any water around the contacts and put the cart back in, then go back to the cleaning. If the problem is not solved after this unfortunatly its time to bin the printer because the time to install and cost of the head is generally more than its worth (Not always but mostly the case)
Hope this fixsya
May 06, 2009 | Brother MFC-640CW All-In-One InkJet...
No magenta
It sounds like the problem is either the drum or the megenta developer assembly. The drum is a consumable you can replace. The other usually involves a technician...in other words, very expensive.
Jan 28, 2009 | Dell 5100cn Laser Printer
HP PSC 1500 xi Cartridge Error Problem
You do need both cartridges installed in order to use the printer. Even if one is near empty it will print (although your quality may suffer).
Jan 16, 2009 | HP PSC 1510 All-In-One InkJet Printer
Canon i9900 isn't printing photo magenta
Use denatured alcohol to soak the print head. Then use suction to draw the alcohol back thru to the foam ports where the ink cartridges rest. Continue until the alcohol runs clear. Then use water and then repeat with alcohol. Allow to dry and re-install in printer. Use new ink cartridges when re-starting printing.
Dec 31, 2008 | Canon i9900 InkJet Photo Printer
How to refill hp 818 inkjet cartridge
First Hole light cyan, scond hole cyan, third hole megenta, fourth hole yellow, fifth hole light megenta. now check. it will support Photo quality.
Dec 03, 2008 | HP DeskJet F4280 All In One Printer InkJet
HP Photosmart 3210 All-In-One InkJet Printer Logo
93 people viewed this question
Seeker5211
Seeker5211
