Question about Honda 6370C - Parallel Power Kit For EU3000i
Wont run off 1/2 choke - Honda 6370C - Parallel Power Kit For EU3000i
    Problem Solver:
  • 5 Answers
I had a problem with a honda generator that would only run on full choke. I removed the carburetor and cleaned the main jet with a wire and carb spray. Problem solved. Fuel stabilizer should be used with todays gas mixtures that have ethanol in them. Hope this helps.
Posted on Aug 31, 2010
Have a 4 stroke generator eagle blue model eg1100w will start easy enough but wont run when take the choke all the way of. run good on half choke
I think your mixture may be a bit too lean or too rich... have a play with the mixture screw but only using tiny increments 1/8 of a turn - bit of trial and error involved thats all...
Good Luck
May 06, 2017 | Electrical Supplies
Honda cg160 tiller the engine was running rough With choke all the way in, fine at halfway. then stopped moving forward,moves but no strength to till. What's wrong??
while your choke is out your engine is getting too much petrol . if it wont run well with choke in then its not getting enough. there is a small screw on the side of the carb ( air mixture ) they are usualy ( from screwed right in ) 1 and a half turns out, try with 1 and a half turns out start engine and adust either way so it idles nice ( try and warm engine up first ) also if you can't get it to idle you might have to strip card off and clean it ...hope this helps
Apr 23, 2015 | Honda Garden
Got spark good compression. and fule. electric choke. but wont stay running when cold.
The electric choke may not be getting power. The power wire for the electric choke is usually connected to the ignition "on" switch. When the electric choke coil is energized it will open the carb choke plate completely after approximately 3.5 min. Some potential problems could be: 1, The electric choke is getting constant power and therefore is always open or has no power. 2. The carb choke plate needs to be adjusted or the plate hangs up when opening or closing.
Mar 02, 2015 | Motorcycles
Harley wont start with choke on,but can start it with choke off
Hi Cully, if you have a carburator the usual suspects are:
1. Damaged or restricted fuel tank venting system (gas cap).
2. Inlet system air leak.
3. Vacuum piston malfunction.
4. Accelerator pump leaking or no output.
5. Plugged bowl vent.
6. Fuel level (float chamber) too low.
7. Restriccted fuel supply passages.
8. Plugged jets or passages.
9. Worn or damaged needle or needle jet.
10. Enrichner valve not seated or leaking.
Good luck
Jun 03, 2012 | 2001 Harley Davidson XL 1200 C Sportster...
I have a mtd 3.5hp 21" snow blower it was bought new in 11/06 the problem im having is stalling it starts ok some times other times it stalls and won't run others it will only run at full choke if...
Try running some fuel system cleaner through it. A good choice is Chem Tools Berryman B-12. There are some hardworking solvents in the product that could help you overcome a dirty carburetor. Initially use a good, strong dose. Maybe double what they recommend . (1 oz/gallon). If this doesn't work, the carb will probably need to be removed and inspected and cleaned.
Feb 03, 2011 | Garden
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
I have a gsxr 750 1990 the L modelk its in good condition and has been well cared for.when I bought it running grand but needs to have carbs balanced out as running a bit rich on 1 plug. it wont start, its...
Don't use cold start.it will not solve your problem.Try running it with out the air cleaners ,it may be that you have an air intake problem and not getting the right Air / fuel mixture .
Mar 13, 2010 | 1990 Suzuki GSX-R 750 L
Weedeater wont run
Take the red and blue limiters off to adjust. Back out 1- 1 1/4 turns and go from there.
Jun 22, 2009 | Poulan Garden
Pressure washer wont run unless choke is on
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
May 12, 2008 | Karcher 2500 PSI Pressure Washer
Honda 6370C - Parallel Power Kit For  EU3000i Logo
441 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
