Question about Toshiba 50H81 50" Rear Projection Television
When I turn on the TV the screen has static
The TV turns on but the whole screen has static, I can go to the menu and that will show up on screen but no picture.
  • 4,234 Answers
Static usually means that the tuner is not working. Chack all of your cable connections first. As a quick test of the tuner itself, remove the cable from the exterior antenna connection and insert a small paper clip. That will act like an antenna and if you scan for channels, something should be seen. If not, then you probably have a bad tuner or have lost the source power for the tuner.
Dan
Posted on May 07, 2008
Emerson ewf2004a tv static lines moving from bottom to top tv screen
do the lines travel through the menu ?(when menu is turned on) if not it's likely a problem with the signal, loose antenna or video input connection. You can also try another input, a DVD for example. If the menu is distorted by the line, then it's probably something inside the TV
Nov 15, 2017 | Emerson Televison & Video
TV has static but no picture. When I turn on the TV, I hear 2 clicks and static. Pushing the power button again, static stops and red LED light turns on. After 15 min. TV automatically shuts off.
Check your antenna is plugged in the right place.
Switch TV on then goto it's menu setting, if the menu appears then at least you know the screen works.
As a test, plug in a DVD player to one of the HDMI ports and try to play something. Make sure you select the proper input source from the source menu and see if you get a picture.
If you do then it narrows the problem down.
Next, from the menu, select TV source to see if picture comes.
There are a number of other sequences depending on what decoder or Viewer box you have, if it's just Freeview antenna then you may have a problem with that.
Make sure you've done the auto tune procedures too.....
Oct 11, 2016 | Televison & Video
How to fix the problem of half black screen on my toshiba led tv?
On your TV remote go to menu , either video or picture settings and make sure it is on HD ( high definition )
Aug 01, 2015 | Toshiba Televison & Video
When I turn on my sharp tv all I get is static. How do I get rid of the static and have tv shows
go to menu and press the "auto search program" wait till the unit have fixed good signals itself. If doesnt have found good signals?... your TV tuner is not good.
Jun 30, 2014 | Sharp 13N-M100 13" TV
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
Toshiba 65H81 Displays static, however menu screens fine
Well in this case you may have an issue with your Video Board, if the static showed on the menu, then the issue would have been with your DMD Board, but not in this case.
Jul 27, 2009 | Toshiba Televison & Video
My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON 2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
Jun 03, 2008 | Hisense TL1700 17 in. LCD Television
Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Dec 21, 2007 | Samsung LE32R73BD 32 in. HD-Ready LCD...
ONLY BLACK SCREEN NO CABLE OR AIR SIGNAL
Try going into the menu and doing a reprogramming or auto search for channels.
Sep 16, 2006 | Sharp 36J-S400 36" TV
Toshiba 50H81 50" Rear Projection Television Logo
170 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
