Question about Refrigerators
During holydays, due to an interruption in the power service, the food of the freezer department defrosted, and now there is bad odour in the fridge. I cleaned it, but the odour did not disappear. What could I do? Thank you very much.
  • 3,740 Answers
Hi and welcome to FixYa I am Kelly. If you are using it and need to keep using it buy about 4 boxes of arm and hammer baking soda and cut the top off. Place 3 in fresh food compartment and one in the freezer. It takes time but it does eventually pull out that odor. However... you need to look under the refrigerator at the water catch basin plastic tray. Often liquids from a defrosted refrigerator drain into the pan down there and dry out. Then everytime the unit auto defrosts (2 - 3 times a day that) bad odor is noticed again because the water produced from defrosting liquifies the material in the plastic tray. You should clean that tray really well and wipe out all of the black goo / gunk. Make sure you look at the very end of the cabinet drain tube also that terminates in that same pan. I have found that using Mr. Muscle mold and mildew cleaner does a really good job of cleaning and removing that foul smell. A trade secret here we use Endust on a dry clean inner cabinet to make them smell good and shine.
Thanks for choosing FixYa.
Kelly
Posted on Aug 29, 2010
My refrigerator is not cooling on the refrigerator side
There are so many things that can make your fresh food side not cool. Usually, it is a frosted up evaporator, which is blocking the air flow of cold from coming from the freezer to the fresh food section. This can be caused by a bad defrost timer, a bad defrost thermostat, a bad defrost heater, or a bad control board. It could be a week compressor that is only strong enough to cool the freezer, the evaporator fan may be bad, which blows the cold air from the freezer to the fresh food section, the damper control going from the freezer to the fresh food section, can be stuck in the closed position, or in rare cases, the light in the fresh food section can be staying on, or even the condenser fan that is responsible for keeping the compressor and condenser from getting to hot, may be bad. This is usually behind the bottom of the fridge. You might also have a dirty condenser, which is the coil that is usually underneath the fridge. So you are most likely going to have to call for service.
Jan 29, 2015 | Refrigerators
Several times now my freezer & refrig. stopped working. Ice buildup on back of freezer wall. Especially if there is content in it. The icemaker I think was spilling water down the back (missing the...
Sounds like one or more of you defrost coils behind the back wall have gone bad...
You have to purchase the correct coil set for that model, remove the back wall, replace them and put the back cover back in place after emptying the entire contents of the freezer...
Most non HVAC people would prefer a repairman to do it.
Mar 09, 2014 | Kenmore Top Freezer Refrigerator
Wont let cold air blow into the refridgetor side
If it isn't due to the fridge contents obstructing the cold air outlet in the fresh food compartment, it's probably an issue with the thermostat in the fresh food compartment or the fan(s) in the freezer compartment.
It may also be the first indication of a failed part in the defrost circuit. If the freezer compartment begins to warm over the next day or so, there may be an issue with the defrost timer, defrost terminator, or heater. Before digging around there tho, make sure the cold air openings in the fresh food compartment are not blocked.
If the fan(s) in the freezer have failed, they won't be able to blow the cold air into the fresh food area. If the thermostat failed, it will never be able to send power to the fan to cool the fresh food compartment.
Depending on your capabilities, this may or may not be a good DIY type job. Sometimes, a warm fridge / freezer is due to a refrigerant leak, and will require a licensed refrigerant tech to make repairs. Working in the tight confines of a fridge can be difficult - especially when testing components with power on.
I hope this helps - good luck!
Oct 21, 2010 | Refrigerators
Got a hotpoint ffa97, freezer was still cold and no alarm had gone off to say that that there had been a power cut yet the fridge temp had risen enough to curdle milk??\r\ntemp gauge was still showing...
Milk can sometimes curdle in a working fridge. But it does sound like your defrost system may be malfunctioning. Can you empty your freezer and inspect the defrost system behind the air circulator fan?
I know that defrost elements sometimes go bad and the controllers can pop too. You should check your operators manual and see how to put the fridge into manual defrost. *(it usually involves turning the fridge light on and off by hand. See if the freezer drains during manual defrost. If you have lots of food that dries out in a frost free unit the moisture contains a lot of contaminants that can plug the defrost drain. Which leads to a blocked air passage between the freezer and fridge sides.
You might want to get a small backup fridge for a while to run this down.
Or just use up the food in your fridge before running the tests.
Good luck and be careful.
Jun 28, 2010 | Hotpoint Refrigerators
Freezer on top leaks water into fridge during defrost of freezer
This would be due to a clog in the defrost drain. I have put together some information on cleaning this out. Follow the link below and let me know if it was helpful.
Defrost Drain Cleaning
May 21, 2010 | Refrigerators
Not keeping food cold and popping noise
There is ice buildup in an area that you cannot see.
The interior wall may "bulge" a little if the ice builds up a lot.
1. You may have the cooling dial set too high (use lower numbers)
2. The blower vent into the fridge or freezer maybe blocked (move items away from vents inside)
3. Defrost the fridge. The water pan underneath the refrigerator may overflow.
If there is no "defrost" setting, unplug for an hour (don't open refrigerator or freezer during defrost)
Plug back in, food will not spoil.
Sep 21, 2009 | Haier Refrigerators
Freezer is defrosting
Many times, on a fridge with automatic defrosting, there is a sensor at the back of the freezer section (behind the plastic) that detects a freeze condition - sometimes these go bad, In normal operation, usually once a day, the timer sends a signal through this sensor and if it shows a frozen condition, it activate a heater (yes, a heater) in the freezer section that melts and defrost the coils. If this system stops working, the ice builds up and closes up the air passages to the fridge section, causing it to warm up, while the freezer section ices up!
Check for icing and maybe try defrosting a little by removing power for a little while. Move any food to another fridge while you are fixing it. The freeze sensors are easy to change, but be careful - electricity can kill. Always hire a professional if you have any doubts about your ability to perform the work yourself.
Aug 30, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
My Norcold DE0051 I have to keep defrosting every 2 weeks
Occasional defrosting is needed on these units. 2 weeks isn't that bad considering the environment that it is in (your boat). Every time that you open the door, moist air enters the fridge, and the moisture eventually collects on the freezer plate, and freezes. Putting foods into the freezer that are uncovered also contribute to this a great deal, as do putting in warm / hot foods before giving chance to cool down.
These freezers do not have automatic defrosters. The target environment typically has limited power available. Automatic defrosters would easily double the power requirements.
You can also check the door seals on your fridge as well. If they are not sealing properly, they can also let in humid air which then causes moisture to collect on freezer plate.
Aug 10, 2009 | Thetford Norcold DE0051 Refrigerator
Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Maytag MSD2650HES Stainless Steel Side by...
Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Oct 03, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
