Question about Acer Aspire 5000 Notebook
Hi Have brought a second hand Acer aspire 5000 laptop for a $100.00 dollars for my sons birthday was told battary light was flashing amber and it needed new battary as wouldn't run of power they said it would go if new battery was put in,when it arrived to me i brought new battary and put it in and used power cord as well and have no power lights coming on at all and wont turn on at all. can some one help me what is wrong with it
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Aug 29, 2010
Testimonial: "Thanks for this am trying what you said now and hopefully will have some luck Thanks again Reece"
2 Suggested Answers
  • 2567 Answers
SOURCE: Hi Have brought a second hand Acer aspire 5000
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 08, 2010
Power light flashing amber
Follow the steps given below. (Please be careful when handling computer electrical components like batteries and AC Adapters)
  • Remove the battery and hold down the power button for few seconds (to drain all remaining power)
  • Power up the computer without the battery with the A/C adapter plugged in.
  • Wait for few seconds and plug the battery back in
After a few tries the computer should start charging normally. The amber battery stops blinking and turn green when fully charged.
Feb 13, 2015 | Acer Aspire One Kav10 Netbook
How do I turn on wireless?
Hi:
On the right hand side on the bottom edge of the notebook you will find the amber light and the switch, just move the button to the right and let go. The light will start blinking and on your desktop u will see the signal.
Sep 12, 2011 | Acer Aspire One PC Notebook
Hi Have brought a second hand Acer aspire 5000 laptop for a $100.00 dollars for my sons birthday was told battary light was flashing amber and it needed new battary as wouldn't run of power they said it...
Aug 29, 2010 | Acer Aspire 5000 Notebook
Acer aspire 4930g,charging, at first 1% to 95% the
yes you labtop battary driver may be currepted. so install fresh battary driver
Apr 29, 2009 | Acer Aspire 4930-6862 Laptop
Acer Aspire 5000 was dropped and won't power on
Hi there, I'm afraid that a physical damage affected your laptop.
But anyways, unplug the power cord, and remove the battery. Wait few seconds then push the power button and hold it for 10/15 seconds. Re insert the battery and reconnect the power cord and try to turn it on again.
Good luck
Mar 30, 2009 | Acer Aspire 5000 Notebook
My acer aspire 9300 doesn't turn on.
Try this
Remove all power from the computer
Laoptop: remove the battary & the power plug
Desk top: remove the power plug
Hold the power button for 60 seconds
Plug your PC on and reboot
Feb 18, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 5000 laptop with SiS 760_M760 video driver
The Aspire 5000 actually has a 128mb video card. i am using one right now as a matter of fact. Reboot your acer. when you see the acer logo. press F2 once into the bios screen move to the next tab. High light the 64mb next to the video adaptor and high light 128mb.
Feb 06, 2009 | Acer Aspire 5000 Notebook
AMBER LIGHT FLASHING WHEN CHARGING
yes it flashes as it charges..Which os is installed in your laptop.
Dec 08, 2008 | Acer Aspire 5315 Notebook
Charging the battery the amber light comes on, but then after a while the amber light flashes. Does this mean the battery is charged? It used to turn to green with the battery that came with my...
if it turns green that means that it is charged, but it then if it turns amber that means that it is going bad
thanks
hope this works for you
Aug 27, 2008 | Acer Computers & Internet
Acer laptop
Hi, I'm not sure if that is a built-in feature of the Aspire 3000 (AS3004WLCI) but not in your Aspire 5634WLMI but I think that it is an add-on software utility. You may want to try this http://www.nonags.com/nonags/emn.html. It offers freeware E-Mail Notification software flashing scroll-lock light. Hope this works for you. Please let me know how things turn out. Regards.
Apr 09, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5000 Notebook Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
