My Ariston A1437 will start working as normal and then both the lock light, easy iron and rapid buttons flash and then the washing machine stops after about 3 minutes. Any help muchly appreciated!
I had this problem last year and had to call an engineer out. The problem was not with the washing machine but with the drainage pipe to the sink unit which had become 'backed up' with softener and the machine could not empty properly. 1 year on I now have the other 2 lights flashing and need to find out why. Any help gratefully received!
Posted on Oct 21, 2010
Ariston avxl 129 washing machine has stopped working.
This washer does not have a good track record. There are many many complaints out their on this brand in general. It is also not a cheap purchase.
1st. Suspect is the mother board followed by the motor.
Nov 20, 2011 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston a1636 washing machine
I have the same problem, did this get solved for you?
Jan 08, 2008 | Ariston Technologies AW149NA Washer
Fault with Ariston Washer/Dryer
Make sure the filter is clean, its behind the front bottom panel which just pull off, then unscrew the filter thumb wheel until it comes out. Check it is clean and replace, Now unplug the machine and set the programme to your normal start setting leaving the door open. Remove the screws retaining the back panel and unplug all the connectors to the circuit board found in the bottom left hand corner. Turn the power back on ensuring the red LED illuminates and leave for 2 or 3 minutes before unplugging the power again and reconnecting the circuit boards and replacing the back panel. Reconnect the power and turn the machine on, close the door and with luck it will work. If this does not clear the fault repeat the process again or look on ebay for a new machine!
Oct 13, 2007 | Washing Machines
Ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
Oct 07, 2007 | Ariston Technologies AWD 121
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
