Question about LG Washing Machines
Hi! My LG Intellowasher fills up with water, but then it doesn't do anything else. Any idea why/what this is? It's a 7kg front loader WD 1021 WH
After pressing star button water does not fill and after 10 sec all the temp lights flash
Posted on Sep 01, 2010
    President:
  • 1,197 Answers
Pretty easy fix with a couple of strong backs. Get some pillows, lay machine on its side opposite of the lint door so pump can be seen from bottom. Unscrew cover, then 2 remaining screws that hold pump assy to machine frame. 3 screws hold motor to pump housing that is now pretty easy to get to. mark wires and disconnect. My guess is once you have motor out yo will likely find an offending coin or something. What happens is lint screen eventually needs cleaned, but something like a coin will rest on top of it and when you remove screen by default it will fall into tube to the pump, just has no where else to go, and it's a murphys law thing. Since pump is brushless, the coin likely does no harm except mess up your day, Reverse process, Wash away
Posted on Aug 29, 2010
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
I have a lg intellowasher 7kg wd-8015c (front loader), and its not spinning and the clothes come out wet. whats wrong and what parts will i need please
If the washer is not spinning you need to check on the motor, motor capacitor and the power from the program controller unit. If there is no power to the motor then the controller is a suspect.
Please check this link for tips: removing the motor:
Jun 23, 2012 | Washing Machines
LG front Loader Intellowasher 7kg WD-8015c has been on a quick 30 mins cyle and is still going after 1 hours just keeps spinning and won't turn off
I have the EXACT same problem wit the LG 8015C. After numerous attempts, I finally found the problem. A set of wires attached to the drum body vibrates against th erear panel, wears off the plastic insulation, shorts and blows the circuit board. All because of sloppy workmanship ! It took 4 years of easy work for this to occur. Will NEVER buy an LG or Front Loader again
Sep 18, 2009 | Washing Machines
LG Intellowasher cannot complete spin cycle.
Unplug power cable, remove top cover and inner panel, locate water level sensor on the right with 3 wires and a thin tube, remove the tube and puff into it until you hear water bubbling. This will clear any blockage caused by suds build up. Replace tube, covers and plug back in. It should complete cycles now.
Sep 11, 2008 | Washing Machines
Washing Machines Logo
286 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
