Question about Tanita BC-533 InnerScan Body Comp Scale
Ive got a bc 532 body composition moniter and ive put new batteries in it and its not working. When you press the guest button the display shows 88888 but none of the other buttons do anything. Ive tried two sets of new batteries and its the same with both.
  • 19,396 Answers
Hi.
That means that our personal data has not been programmed, follow the steps on p.3 on manual below.
Make sure socks or stockings are removed, and the soles of your feet are clean and properly aligned with the guides on the measuring platform.
If that does not work, try using guest mode ( one time wighting with no programming). If the unit does not set up in guest mode, or if does not self program, contact the manufacturer, as unit may be faulty. Contact page.
Click here to download the manual.
Posted on Aug 29, 2010
Hello, my new device Tanita BC 532 measure weight and body fat%, but no reaction when I try to press rest of the featured keys. I use the description attached, and the weigth and fat% showes alternly on...
My Tanita BC-532 also developed this fault. It seems to be common with a number of the models! I asked Tanita and over a number of emails this is what they said:
"not to place it in wet rooms and remove the batteries if stored for a longer time period."
When I said it was in a bathroom (isn't that where everyone keeps their scales) NOT a wet room - they said any bathroom is classed as a wetroom!
When I said how can you tell if the batteries are just about to run out (that's what seems to trigger the fault) I had no reply; and when I asked how long is a "long period of time" - 2 weeks/ 2 months (we used to use ours every 1-2 weeks) again no reply to this question.
Now out of warranty after 5 years Tanita suggested it I didn't follow either of these instructions above (in the manual, but not defined) then I only have myself to blame. They did suggest one remedy was to:
"1.Take out the batteries.
2.Make a short-circuit between (+) and (-)with a piece of wire.
3.Put the batteries back and try it out.
If that doesn't work, you simply have to discard it. "
Personally I don't think this is satisfactory and I won't buy Tanita again. Scales should last much longer. They should make any warnings clearly defined - especially based on the number of times this happens according to reports from users on internet.
It seems this is a well known fault and I would thus suggest scales are not fit for purpose over longer term. Tanita should own up to this and stop avoiding their responsibilities.
Should you not keep in the bathroom, use every few days, and replace batteries before they get too low - then these scales are great (well they were for the first 5 years!)
Dec 25, 2010 | Tanita BC-533 InnerScan Body Comp Scale
Dear Sirs, I am from Brazil. I bought a Tanita BC533 two years ago. I have seldom use it. Last time, it was three months ago. Today, I try to use it but the 0.0 does not come on the display, just...
Try to reset the electronics to factory defaults. If that does not work then the unit is no good. If no reset button check with the mfg for the protocol to do this.
Sep 23, 2017 | Tanita BC-533 InnerScan Body Comp Scale
Need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
Tanita innerscan stopped working. New batteries installed but will not switch on. There is no display except on the guest button which comes up with "88888" when pressed. Any ideas - thanks
Maria,
sorry no, i don't have a sltn. however i recently experienced the same issue w/ my tanita innerscan. i've just notified Tanita's customer service... have you had any progress?
Dec 30, 2009 | Tanita BC-533 InnerScan Body Comp Scale
How do I reset
Hi!
Press the Set button to turn on the unit (once programmed, tapping a Personal
Key turns on the unit.) The unit will beep to confirm activation, the Personal Key
numbers (1,2,3,4) will be displayed, and the display will flash.
If you don’t operate the unit for sixty seconds after the unit has been turned on, the unit
will turn off automatically.
If you make a mistake or want to turn the unit off before you have finished
programming it, press the Weight-Only Key to force quit.
Press the Up/Down buttons to select a Personal Key. Once you reach the
Personal Key number you wish to use, press the Set button.
The unit will beep once to confirm.
An arrow icon appears on the left side to indicate age setting.
Use the Up/Down buttons to scroll through numbers.
When you reach your age -press the Set button.
Use the Up/Down buttons to scroll through female or male,
Female/Athlete and Male/Athlete settings, then press the Set button.
Use the Up/Down buttons to specify Height and
The unit will beep twice and the display will flash all data three times to confirm the programming.
The power will shut down automatically.
Good Luck! :)
Cathy
Oct 21, 2009 | Tanita BC 554 Ironman Innerscan Body...
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Ive got a factory radio reading of i have code how do i reset to put in code
When you turn on the radio, it will say "codE" on the display. You have the 4-digit code number for your radio, to enter the first digit, press the "1" button on the radio the number of times until the first digit matches. For example, if your code is "2156" then, press radio preset button 1 two 2 times, then press radio preset button 2 one time, then radio preset button 3 five 5 times and finally preset button 4 six times.
THEN if the display is correct (should show 2156 in this example), press TAPE button. You should hear a beep and the radio should be working. If you make a mistake and enter a wrong code, the display will show "Err". You have 3 tries to get this correct or the radio may be toast. These are the steps for the stock radio in my 1995 GSX and they've worked for me each time I've lost battery power. Good luck!
Apr 09, 2009 | 1995 Mitsubishi Eclipse
Canon eos1
According to the manual, this indicates either (1) the battery is low and needs to be replaced, or (2) the internal self test is failing when the shutter button is depressed half-way. For the latter condition, they recommend removing the battery completely, then reinserting and pressing the battery check button (second button down under the 'palm' door).
If you still get the blinking 'bc', it indicates the camera needs service.
May 19, 2008 | Canon Photography
Tanita BC-533 InnerScan Body Comp Scale Logo
315 people viewed this question
Top Tanita Health & Beauty Experts
dkmun
Level 1 Expert
Ankit Chandel
Ankit Chandel
Terry
Terry
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
