Question about LaCie (300770) 250 GB Hard Drive
I am trying to update my back up but I get a message the disc is full (although it does not appear to be when I look at its porperties). I am instructed to delete and backup the files again and when I try to do this I get the message: Access to the path "autoConfig.ini" is denied.
  • muhrynuk Aug 29, 2010
    The disc system is NTFS
  • 43 Answers
I thing your file system is FAT32.fat 32 can only store file size of maximum of 4GB.change file system to NTFS.
To convert a volume to NTFS from the command prompt
  1. Open Command Prompt. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. In the command prompt window, type: convert drive_letter: /fs:ntfs
For example, typing convert X: /fs:ntfs would format drive X: with the ntfs format.
Posted on Aug 29, 2010
  • Vivek v
    Vivek v Aug 29, 2010
    try defragmenting the disk
    start->all pgms->accessories -> system tools ->disk defragmenter
How do I fix a No Disc error given by my VIZIO Blu-Ray player?
Have you checked to see if the software is current on your player? If so do other discs function properly? Go to menu, chek to see current software, if current you can contact mfg. To see if it in fact current. Sometimes they have to be uptaded via cd. Retun disc to store get new one, try it to make sure. I have two 3d bl ray players and neither will play them. Software is not updated for these discs.
Feb 27, 2015 | Vizio VBR220 Blu-Ray Player
416b-4174-b680-0f00-c000-0034
I had this error code as well. Here's the solution that ended up working for me:
  1. Eject the disc tray and remove any disc from the console.
  2. Important: Do not close the disc tray. Leave it open.
  3. With the disc tray open, remove the power cord from the back of the console.
  4. Gently push the disc tray about half-way back into the console.
  5. Plug the power cord back into the console.
  6. Push the power button on the console. The tray should close the rest of the way, then the console should restart and display the Xbox Dashboard.
  7. Important Do not use the controller or the disc eject button to turn on the console.
  8. Try updating your console software again.
What this does is put the DVD drive into Mode-B, which is an alternate operating state that allows the drive's physical memory banks to be flashed with new firmware. Because the latest XBL update involves flashing the drive with new firmware, you may need to physically put the drive in Mode-B. The latest update flashes the drive to make it compatible with Microsoft's new high-capacity disc format, XGD3, which will be used sometime in the future.
Jun 10, 2014 | Microsoft Xbox 360 Console
Hi ! Every time I try to send a text message, it appears Memory full! Close some applications and try again.I did erase my pics as well as those file saved in my memory card, but it still hopeless. It's 3...
Go your message setting. There is option where you'll save your message and choose save to memory card.
Delete all message in inbox and outbox folder, delete all cache in your browser and close all active applications. Try to send text message.
If the notification "Memory full" still appear you must uninstall a one or more application (not just close it but uninstall it) to make some space in your phone memory. Choose application that you don't use the most.
If the problem persist, format your phone back to factory setting.
Hope this help and if helpful RATE please.
Feb 09, 2011 | Nokia 3230
When trying to delete something from hard drive i get an error message stating. Cannot delete Acess denied make sure disc is not full or write proteced and that the file is not currently in use. This...
The possible couse of that is your hard drive is infected of virus, try to scan of updated antivirus, if not try to back-up your hard drive, and format in desk management.
Apr 17, 2010 | Iomega (33652) 250 GB IDE Hard Drive
I am receiving the message "no valid disc" on the dual screens...
it appears yous direct drive motor is damaged. When a disc does not spin, it will say the same as a bad disc. You can easily get this fixed, but not cost efficient. Better off replacing it the component.
Jul 24, 2009 | kawasaki PVS1965 Portable DVD Player
Cyberhome DVR 1600, where can I get the firmware update
Hi there
The best bet now the company has gone bust is trawl through the forums to see in anyone has a firmware upgrade saved and available for download. Here is a good start.
http://www.avforums.com/forums/index.php
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Cyberhome DVD Recorder - DVR1600
"loading" message appears several minutes, then "no disc" message
check another disk.
or your dvd lens is weak to read dvd
i think it can read cds now.
if not, try to update firm ware or your dvd.
Jan 17, 2009 | Televison & Video
Incompatible Disc in Sharp BD-HP21X Blu-Ray Disc Player
I had the exact same problem as you did... I bought the Sharp Aquos 42D85X which came with Sharp BD-HP21X Blu-ray Disc player. could not get brand new blu-ray movies to play and i found it froze everytime after 10 secs. I phoned sharp who basically were no help watsoever! I then went and returned my blu-ray movies back to the store thinking it was a problem with the discs.. The people there were extremely nice and since they had a display model of the BD-HP21X instore they offered to test the movie on it to veroify whether it was the blu-ray player was the problem or not. Turns out its a fault with all of the BD-HP21X models. So we then ended up returning it back to the store we bought it and exchanged it with the older model (BD-HP20X). I now have no problems playing blu-ray movies. Although another suggestion is to perhaps download the lastest firmware update & see if that resolves your issues.
Dec 25, 2008 | Televison & Video
Can't launch Internet
seems like there is DNS confiuration set in the wirless porperties page.
right click on the "My network Places" go to porperties. right click on the wirless connection.
go to TCP/IP under the "connection uses the following items." high lite the TCP/IP adn select the porperties box.
under hte genral tab
Obtians an IP address automatically
under alternate configuration
make sure nothing is checked. click OK and close.
try to connect again.
Oct 28, 2008 | 2wire 1800HG Router (RG1800HG00)
LaCie (300770) 250 GB Hard Drive Logo
114 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
