Main component to cause such an issue in the DC socket where you plug the power adapter. This is one of the weakest points in the laptop & usually the first suspect when it comes to input power failure. The socket might either be loose (in which case it will need to be re-soldered), or broken (in which case it will need to be replaced). In either case, you need to disassemble the laptop, pull the motherboard out, & inspect & fix the problem.
test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
One bad lead or faulty connection point can cause a computer to shutdown continue restarting on a cycle or fail to detect your hard drive boot up
hope it helps
