Question about Nintendo DS Lite Console
Ndsl power problem
Aquired ds lite from brother. he bought brand new ds lite due to broken hinge. It sat without use for a long while til he gave it to me. i notice off bat that upon turning it on bottom screen will flash on then system would turn off. put on charger...charging lite would come on as normal but when i tryd again same thing. so i bought new battery from nintendo and again same...charged it again same...what is wrong with it and is it fixable?!
  • Bob Kochis May 11, 2010
    Did you repair the broken hinge yet? When the hinge breaks it usually damages the cable for the top screen, so the top screen would need to be replaced.
    The 'bottom screen flash and then turn off' is indicative of a broken top screen 99% of the time. The other 1% is that the console was repaired and the top screen cable is not inserted correctly into the motherboard.
    Thanks, Bob
    Guru:
  • 155 Answers
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
Posted on May 13, 2008
I bought a ra(ndsl/nds ) for my ds lite and
Mine works fine!!
Download English 1.18 from the R4 website.
Unzip
You should have 4 files on your card
_system_
moonshell
_DS_MENU_DAT
_DS_MSH_NDS
you then add the .nds game files from wherever you get them from
Make sure the card is formatted first, ie there are no other files on it. try FAT. rather than FAT 32. I can't remember which but I've had no problems with either the card or the software, best thing since sliced bread, and it only cost me a tenner.
Dec 19, 2009 | Nintendo DS Lite Console
A pin in the slot 1 is broken
as long as it is still in place it should still work
Apr 17, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Broken Right Hinge & failure to stay powered on
the nintendo DS IS A *******!!!!!!!!!!!!!!!!! PIECE OF **** YOU ******* ****
Feb 07, 2009 | Nintendo DS Lite Console
Ds touch screen and main screen not working - connectors broken
if you would have sent it to me first I would have replaced the case for you and you wouldn't have had these problems, but I can still help you out. I have a white nintendo DS lite in stock that I had to replace the bottom lcd display in. I will ship to you for $90 and if you are feeling adventurous send me your parts and I will take off $10 since I have no clue what is broken and what is not, but to me it sounds like the bottom lcd, touch screen , and circuit board are trash.
Thanks
Josh Boyer
ninja_freak318@hotmail.com
Jan 22, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Flickering screen
hey i think i got a solution, read the link i gave below credits to votahuan, its for adjusting screen flickers in both top and lower screen of ndsl, however i need you to do me a favor in return, hope you do not mind posting up the pics for me at renginez@yahoo.com once you found the two hidden screw at ndsl, im just having hard time finding it in fat nds, so i need a rough i dea of where it mite be located. Heere's the link anyways :-
LCD FLICKER SOLUTION
Jun 15, 2008 | Nintendo DS Lite Console
DS broken in half
I recommend you to change the broken case, you can choose to change only the hinge and keep the good case parts or change the entire shell. By the way stores usually sell the entire shell so you can choose. As your screens are still working you are lucky because so often the brown flexible conductor to the top screen get broken so be careful.
You can also use a silicon or hard plastic case to put over your broken NDSL to keep it in place just as the fast non technical option.
Here are some links and you can find text and video guides googling around.
Shells in ebay
Other stores items
Good Luck...
Nov 09, 2007 | Nintendo DS Lite Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
134 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
