Question about Fisher and Paykel Fisher & Paykel Washer
Dryer does not switch off when dry.Kelvinator ED 52 K,auto sensor ,when on extra dry mode.
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
When i start dryer it goes from time dry to sensor dry i can unplug it for a few mins then replug in and it works for a couple of loads what can be wrong with it
Ain't modern technology grand, if you set your dryer to 60 minute,and the clothing was dry at 34 minutes,the dryer would run and waste power for 26 extra minutes.You would be paying for 26 minutes of electric you didnt need to pay for.
the auto sensor dry is a wonderful,resource conserving,money savings thing
Jul 30, 2011 | Dryers
Electrolux Kelvinator - Unit on defrost
When a heatpump goies into defrost, the unit is in a/c mode. and cool air is inside. You may have a bad reversing valve or bad defrost board.
Sep 25, 2009 | Electrolux E23CS75SS Air Conditioner
Maytag Performa Electric Dryer Won't Start
check the blower wheel, sounds to me like it is loose on the blower motor, common on these dryers. One sure sign would be a warped filter and a rusted top. The blower aint putting out enough and the dryer is over heating .
/uploadswith image
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Auto feature
Faulty selector switch or control card. There is the possibility of a faulty moisture sensor. Can you operate the machine in manual mode ?
Jan 26, 2008 | Whirlpool GEW9250 Electric Dryer
Kelvinator ED 56 Dryer
reach inside and see if the drum turns real easy. It should turn real easy even wth wet clothes in it. if it hard to turn then the motor aint gonna get going gonna run hot and quit.
Jun 27, 2017 | Dryers
Washing Machines Logo
50 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
