Question about Gateway MX8711 Notebook
I'm having the same exact problem 3 times. I sent my laptop to gateway 3 times for the same problem, the 3rd time they have to extend my warrenty. Then it happen the 4 time and gateway would not fix it. This laptop should have be a recall item. Gateway lied about the problem and I never did find out the problem. Did you get yours fixed? 3 times. Its not the AC power cord
  • 2,567 Answers
Don't know exactly what is your problem, but I assume it is related to power issues. Please find below my recommendations:
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Aug 29, 2010
3rd time top has malfunctioned! Once down, will not close. It's a 2008 Audi TT. Dealer has repaired it and said it was the motor. I waited 3 days for repair. What could be the problem? My warrenty ends...
I have had my TT to Audi 12 times and have had to leave it for a week or two several time.
Thru an attorney I took a $ settlement after 7 repairs, I am very sorry I settled ... Audi should to a recall and extended warranty. I too have my warranty running out in October 2011 and only have 33,000 miles on the car ... not sure if I should keep; but with service record they don't even offer me much on trade in with this service record. I am now finding out this issue is not only my issue, my service department has issues with 3-4 Audi TT with the same issue.
I am going to call my attorney general and find out what can be done / reported and possible the better business bureau.
Just wanted to vent.
PS: Last time they replaced my system with the new 2011 system; no issue yet.
May 05, 2011 | 2008 Audi TT Coupe
I purchsed a GPS Nextar in 2009 (Nov) it stopped working before the warrenty ran out, I sent it in to get fixed 3 times, then I got an email which said they would replace it so I sent it in a 4th time now...
You should have the same warranty that came with the original purchase, but check with them to make sure they validate it from the date of exchange. Here's their support site:
http://www.nextar.com/frontend/gps_navigation_systems.asp
Good luck, and hope this helps.
Feb 10, 2011 | GPS
I HAVE A ASER NOTEBOOK LAPTOP AND EVERY TIME I
4 an aspire 1 atom, i just extended da warrenty an' sent it 2 Texas 4 them to fix, XD.
Apr 14, 2010 | Acer Aspire 5050-3242 Notebook
Acer 5920 wont turn on, we bought an extended
This is a common problem with Acers but usually it is the battery and the adapter. Replace the battery as well as the adapter and you shouldn't have any issues. Surges can be the main cause for this or running the laptop hot has also been the culprit.
Apr 02, 2010 | Acer Aspire 5920-6727 Notebook
Can laptop charger pin be fixed
I had the same issue with a Gateway we use for streaming video to our TV. I actually sent it back to gateway as it was still under their 3 year warrenty buy some 2 or 3 weeks.
While some of their parts fail on a regualr basis (DVD drives) I have to say their service is right up there in my book. You can get to a tech pretty much on the first ring to support. They pay shipping of a carton for you to send in the laptop.
While a really good technical person could replace the part on the laptop, letting Gateway deal with it for you is the best solution. That port is soddered to the mother board and that has to be a perfect joint since it is higher voltage than in other parts of the motherboard.
Keep me posted.
Feb 01, 2010 | Gateway MT6705 Notebook
Gateway P-7805u Video issues
This now the third time the problem has arose and you have had it in for repair twice. This indicates that the model range is suffering a generic problem as others are suffering from the same symptoms as you.
Now i don't know what your specific problem is but its usually a faulty graphics chip or card.
I think by now its time that Gateway gave in and gave you a newer model laptop because of the problems its suffering but that going to take a little determination from you, basically moan at them and refuse to give in.
Post back if you need anymore advice.
Good luck.
Aug 18, 2009 | Gateway P-7807u Notebook
Xbox 360 problem
Most likely not.
The normal warranty on an Xbox is 1 year.
Due to the number of consoles with the rrod issue, Microsoft extended the warranty for the rrod specific problem to 3 years .
If you're within the 3 year windows but the tamper seal is broken, you can expect to have to pay for the repair.
Jul 18, 2009 | Video Game Consoles & Games
Wal-mart's computer care is a scam.
I work for the Wal-Mart PC Care program. The PC Care program is free, it provides assistance in installing a year worth of virus protection. Anything beyond that is on a pay for fee service. It does not replace the original Dell warranty (which as pointed out) you were under. The little card board disk hold clearly states that you should save your receipt here. The receipt can be generated again at the local store. A customer can also purchase an extended service that comes info effect after the original warranty expires. It is not a bad plan, but it does pay to read and know what the plan covers. You still need to contact Dell as you are under their warranty. Pre-existing conditions are not covered by any extended service plan.
Dec 06, 2008 | Dell Inspiron 1525 Notebook
Hello, I have a Gateway MT3419 computer that works almost perfectly; the screen is a big problem. Works well, then suddenly goes dark. Can still see images on the screen when tilted towards the light....
Deffinitely worth fixing and be happy it will only cost $200 or less to fix.
Next time make sure you get the extended warrenty, there are 3rd party vendors such as found on amazon that covers this sort of thing.
Sep 25, 2008 | Computers & Internet
Toshiba Satellite L15-S104, Model PSL10U-01X02F--A COMPLETE LEMON!
Christine.
Go back to best buy. the closest one to you. and see about yoru exteneded warranty. Toshiba dont deal with the extended warrentys.A 3rd party company is looking after it for you (best buy) i guess geek squad.. If the warrenty is out and you gotta pay 600 dollors to replace your computer motherboard. all depending on what you use it for an entry level laptop is close to 600 dollors great for web browseing and office use school, some games.
Feb 14, 2008 | Toshiba Satellite L15-S104 Notebook
Gateway MX8711 Notebook Logo
67 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
