Question about Hotpoint Washing Machines
Ive got a hotpoint wdd960 which has come up as no water supply on the display ive had the hoses off the back and checked water is coming through.i left it alone for a while then it started doing something and displayed f01 on the display,any ideas?
    Sergeant:
  • 209 Answers
There are two small inlet filters on the pipe connections inside the machine, maybe a blockage there.
Posted on Aug 29, 2010
  • col_paul May 29, 2011
    how do you clean them or get to them???
  • Bobby G
    Bobby G May 29, 2011
    Remove the pipes at the back of the machine and look inside the holes on the inlet pipes The small filters can be genty pulled out with a pair of long nose pliers and cleaned.
Hotpoint washing machine wdd960 is leaking from underneath.
either tub has a leak or one of the hoses has a leak somewhere? if u remove the cabinet then run machine u can see and locate ur leak more easily? by the way a tub leak can be repaired some times with some water proof selant
Jan 09, 2015 | Hotpoint Washing Machines
Hotpoint WDD960 F13 code, water not pumping out.
hi if you wash small childrens clothes such as small socks they can get between the door seal and drum. they then get trapped in the rubber hose between the drum and pump which would create the problem you are describing.you would find this hose under the washer.
Jun 25, 2013 | Hotpoint Ultima WF860 Front Load Washer
Wdd960 f13 error code
you could have a problem with the fill valve,shut the water supply off,remove the hoses from the back of washer and mark them so you put them back the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses you'll know it's the washer and not the house water valve.if water comes out look into the washer valve where the hoses connect,if you see alot of junk on the screens change the water valve.i want to tell you that i haven't worked on this machine yet,i looked up your error code and it sounds like you're having water issues from what i've read,there's a tech sheet in the washer sometimes down near the bottom cover or taped onto the side wall,it will have all the error codes and tell you how to run the machine in a diagnostics mode to check everything in it,also next time you write in send the full model number off of the machine you're having problems with so whoever is trying to help you can look up your machine,usually you open the door and look around the opening where the door closes in and you should see a tag with the model and serial numbers.hope this helps,best thing to do is find the tech sheet and run it in diagnostics
Jun 23, 2013 | Washing Machines
Water is not coming in the wishing machine why?
Things to check is the pipe at the back kinked at all also is the tap fully turned on. after checking if pipes are ok see if the washer has a blockage as it is a washer dryer you should clean out the pump more often. Then try resetting machine by unplugging for 5 mins and try starting a cycle if still does not work then you might need a repair to the machine hope this helps.
Jan 08, 2012 | Hotpoint Washing Machines
Hotpoint WDD960 Washer Dryer - no error code but whenever I put it on a dry cycle it just spins as if working but without actually drying. Any suggestions?
Sounds like heating element is not coming on ..Heating first then with a Fan motor running and water flow the steam that is produced by the heaters are changed to water by the cold water over a condenser , the pump then puts his out to waste..
Jan 28, 2011 | Hotpoint Washing Machines
Hotpoint wdd960 washer dryer error f05
f05 means blockage and cannot drain-switch off at mains to reset error-turn to drain if pump runs but dont drain filter in sump blocked/if no pump action then somthing is jammed inn pump
Nov 08, 2009 | Washing Machines
Hotpoint WDD960 Washing Machine - Hot and Cold water inlets. I set my machine up originally with the Y piece, but thought using the hot inlet would be more economical so I have fitted separate hoses. ...
Do you have the hoses on right. Coming from the water supply which you should have two cut offs,looking at them the left one would be the hot line and right cold. Make sure they are hooked up this way on washer and see if you get hot water. If they are hooked up right then either your hot side of the water inlet valve isn't opening or the control board isn't telling it to open.
Sep 15, 2009 | Washing Machines
Hotpoint aquarious + flashing H 20 on display
H20 is indicating that you have no water coming in.
Check water is turned on,check hose(s) are not kinked, and finally check inlet valve.
If you are not sure if there is water to m/c, turn the tap off, disconnect the hose(s), and hold over sink and turn tap back on, water should come out, if it does not, then there is a prob with the supply.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
627 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
