Question about Samsung YP-S3 Digital Media Player
I connected my mp4 to the computer, but then it says CHARGING with a battery icon on my mp4. it doesnt show, connected to computer (or smt like that) like it usually does.
    Sergeant:
  • 209 Answers
Check the setting in the MP4 player and make sure "mass storage" is enabled
Posted on Aug 29, 2010
Lattitude e5520 wouldn't charge
Ted try this once more:
1. turn off the machine.
2. keep pressing the off switch a little longer 3. remove the battery.
4. press the off button for say 15 seconds.
5. re-install battery after a few minutes.
6. connect charger to computer and see if it shows % charge.
7. when it shows 100%disconnect charger and see if the battery still shows 100% If it does you are now reset. IF not,will cross the bridge then.
Jan 24, 2014 | Dell Latitude E5520 Laptop Computer PC...
LCD screen displays always "LOADING" when connected to PC USB
This is a Battery Issue as the Player is only Turning On when its Connected to the Computer!
Dec 29, 2011 | Audio Players & Recorders
Hello there, I own a toshiba c655-s5049 laptop about a year. When I connect a charger taskbar icon shows plugged-in, not charging and the front panel power/battery indicator lights green not orange. When...
Take some alcohol and a q tip and wipe the battery terminals and the terminals on the battery compartment. The laptop not getting a good connection with the battery
Aug 07, 2017 | Toshiba Satellite C655-S5049 Notebook
It won't charge anymore, when it's on it just doesnt say that it's charging, but the light on the charger is on. When it's off, the orange light for charging is on, but it still doesnt charge anyway. I...
The computers contact point for the charging cord is "VERY" sensitive for me. I had to try many times to actually see the charging "icon" light up before letting it charge. Many times the icon would go back to "battery" during charge and I would have to re-try the connection again... Very annoying. If the battery get so drained that you can't see the "charging" icon, then it's a guessing game as to whether it's charging or not. I needed to re-install the OS and it took me 3 days to get my battery charged that way.
Aug 25, 2010 | Motion Computing M1400 Tablet PC
My mp4 is not charging.
It is working but not getting charge
Feb 01, 2010 | Audio Players & Recorders
Cannot charge
SONY NWZ-E436F DIGITAL media player | PROBLEM : my battery was low So i tried charging it by connecting the usb to my computer...it charges for 3-4 seconds till the time it shows do not disconnect the moment it shows connecting it shows the battery sign full.... i tried it again and now it has hung and i try to put it on it just shows every moment has its music...and the battery is still low i believe it doesnt go further
Jun 25, 2009 | Sony Audio Players & Recorders
Mp4 player not charging up
may the connection is lost contact! use multitester to know if your component have continuity? next is battery if have proper voltage of it?
Jan 17, 2009 | Audio Players & Recorders
My Missil Mp4
On the desktop of start menu their should be something called COMPUTER. if you click on that, it shows everything connected to the computer, you should see your missil MP4 connected their. Hope it works!
Dec 26, 2008 | Audio Players & Recorders
Help my MP4 players wont turn on!
Does the icons on the unit show if it's charging? If so the LED is on the charger is bad.
Sep 16, 2008 | Delstar DS-802 Digital Media Player
Audiovox SMT 5600 will not charge
If your battery goes COMPLETELY dead, which it will do if phone is not turned OFF and not used for a long period of time, you will need to JUMP START it using you OEM SMT-5600 AC charger. Other AC chargers will not work for this purpose and neither will a USB port.
You can JUMP START the battery using a USB port by cutting off a USB cable to expost the red and black power USB PORT power pins 1 and 4. Remove your SMT-5600 battery and while the modified USB cable is plugged into your USB PORT, hold the BLACK wire to the negative (-) terminal and the RED wire to the positive (+) terminal for about a minute. Replace the battery in the phone and connect the phone to a USB PORT using a standard USB cable. The SMT-5600 charging light may not register for a while, but will eventually light amber to show it is charging, assuming your phone is recoginzed by your computer.
Note some mini USB cables DONOT carry the USB power leads through to the phone, only data. If you have a very thin USB cable, be suspicious the power leads are not being carried in the cable.
Since the USB PORT power is limited to 100ma it cannot hurt the battery, but will insert enough current into a totally flat batter to cause the battery to register a voltage large enough to alllow USB PORT charging, typically 3.7VDC.
Nov 18, 2006 | Audiovox SMT5600
Samsung YP-S3 Digital Media Player Logo
81 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
