Water is leaking from underneath. We have checked the hoses and door, they are ok. No blockage in drainage pipe.
  • 176 Answers
Check agen
Posted on Aug 29, 2010
Frs26zsh is having wter leaking and freezing at bottom of freezer what can i do
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 06, 2011 | Frigidaire Refrigerators
Hot water won't come out.
hello,
what this indicate is that there is a blockage on the water lay(pipe or drainage ) out for water
what you need to do to fix up this problem from first of all bale out the water from the drum and them trace the pipe that is the way out for water you will see or fine some dry that has block the drainage remove all dirt as the case may be then the problem is solve once you can remove the dirt that has block the drainage .
thank you and thanks for using fixya.
Jun 18, 2010 | Whirlpool WTW5300SQ Top Load Washer
No water fill
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | AEG 24 in. Favorit 40850 Free-standing...
IWater Leak from LG12225FD Washing machine
may be pump...hose seal... in outer tub...cracked inlet valve cracked hose inlet to tub
Aug 17, 2009 | Washing Machines
2002 volkswagen golf gti has a leak in the passerger foot well
hi from uk a common problem with leaks into foot wells are as rain runs down w/screen and inti the bulkhead area below w/screen accesable with bonnet open ? this water runs to either side to a drain hole and onto road via a rubber hose attached to these drains the bottom of hoses are flat so as to let water flow out but not inwards ok so far ?? now leaves and dust etc are sometimes carried to these drains resulting in eventual clogging at bottom and top of hoses so water collects in pools eventually finding its way into car ? take a look at these and ensure hoses are clear ??
Feb 23, 2009 | 2002 Volkswagen GTI
Water drains underneath washer
the load could be to small and all the water whats been left after the wash might be because you only need small pressure on a small wash and the pressure wont make the water evaporate. or you might just need a new drainage pipe i would put less water in next time and see if its better if not get a local self employed plumber.
Dec 01, 2008 | Kenmore 46462 Front Load Washer
Drainage
This normally shows blockage in hose , assuming you have checked and cleaned filter.Glass sherd was the problem with mine , first time then second was block outlet hose cause by backup of garb.Glass was in system at least 4 months before it moved in outlet hose and stopped full drainage.
Mar 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Washing machine
check for blockage in the pump/drainage system. The drain hose has height specifications that should be followed, incorrect drainage may cause the water to build pressure and not evacuate properly.
Jan 31, 2008 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
