Question about Whirlpool GEW9200L Electric Dryer
Whirpool duet washer
Water wont stop running into the machine even whith the power cable unpluged
    Genius:
  • 1,073 Answers
You have something in the water valve on the washer replace the water valve
Posted on May 07, 2008
Water wont stop running into washer
Remove power cord and see if water continues to run with cord unplugged. If so it is the water solenoid inlet valve has failed. Replace.
1396455316233-bzoxlcqgqu45zvuipwpiumby-2-5.jpg Hope this helps?
May 22, 2017 | Washing Machines
Washer wont quit filling even when turned off
If you unplug it and it wont stop, the valve is jammed open with debris etc. It should be replaced. If it stops filling when you unplug the power, there is something wrong with the control board and it is still sending power to the valve even when off.
Feb 19, 2016 | Washing Machines
Water wont cut off
Does the water run if you push the timer dial in to stop the cycle or does it run even if you unplug the washer?
Dec 31, 2011 | Whirlpool LSR7333 Top Load Washer
LG 8kg Fuzzy logic top loader and it will wash and fill the water but the water wont stop when it wash, rinse or spin it, the water also come out even there is no power to the machine.
Assuming the water is coming in even when unit is unplugged from wall. You should to replace the water inlet valves where the hoses connect to the machine. You need to unplug the power and remove the top, disconnect the hoses unhook the wire harness plugs, unscrew the hose valve hex nut and remove valve. Install the new one in reverse order.
May 16, 2011 | Washing Machines
Water wont stop running through machine even when unplugged
Drain valve stuck and open. Or check drain hose damage.
If it is inlet you have to check the inlet valve.
Apr 01, 2010 | Kenmore Elite 45986 Front Load Washer
Washer wont stop filling even when its washing. GE
Replace water inlet valve, it's stuck open. You may try removing hoses to valve and see if something is holding it open
Jun 29, 2009 | Washing Machines
Water will not stop filling wash basket, even when off
Your water fill (mixer) valve is failed in the open position.
CLICK HERE for the part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 20, 2009 | GE WBSE2090A Top Load Washer
Cold water runs continuously at end of cycle
If yo9u were to unplug the machine at that point and the water continues to run in you have a bad water valve. If it stops when yoou unplug it, it may be the timer. Would have to test to see if voltage is present at the valve in the second scenario,. Water valve part# is WH13x10024 @ $51.00
Apr 08, 2009 | GE WJSR2070B Top Load Washer
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
Whirlpool GEW9200L Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
