Question about LG Washing Machines
Its a wd(m)-14220fd/14225fd model were is the drain filter
    Sergeant:
  • 209 Answers
Should be behind the small flap on the front bottom left corner
Posted on Aug 29, 2010
  • rod1973 Aug 29, 2010
    i have now cleaned the filter out and turned the machine on to do a wash .It goes half way through the programme and stops and EU then comes up on the screen any further suggestions please!!
  • Bobby G
    Bobby G Aug 29, 2010
    sounds like the waste outlet is restricted. You may have a small piece of clothing jammed in the pump or waste pipe
I have LG Washing Machine and the water does not drain whilst the machine is washing. What can be wrong?
problem is with main board MOSFET ,FET or Transistor , that are not switching your drain pump at right time , if your'e pump is fine, , you should check drain pump separately by giving it separate supply. ( see its data sheet for power )
Dec 22, 2014 | LG Washing Machines
My LG Washing machine is not spinning. It also comes up with OE. Can you help
Check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
The most common problem with spinning on this model machine is the tub bearing. Normally it would be very noisy when it did spin.
Massive job to replace it.
Dec 06, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
I have an LG washer dryer combo model No. wd-1481rd, it will not drain on the display panel it has "OE" diplayed when put onto drain cycle i have tried to go through complete other cycles and...
Check for clogged/kinked drain hose then open the small door at the lower left of the machine. Located behind the small door is the drain filter and the emergency drain hose. Remove the drain plug and drain the water into a container that's enough to hold such. You may need to drain the water by gravity by placing the drain hose (main) over a container. Position the container as low as possible to extract as much water. Once fully drained, remove the drain filter by turning the knob counterclockwise. Place a piece of the towel under the filter to catch residual water. Clean the filter and try to reach in the pump impeller and check it for restriction or damage. Replace the drain pump if the impeller is damaged or restricted and cannot be freed, or if it just whirs but water doesn't drain.
Aug 20, 2011 | LG Washing Machines
Splendide Model WD 802 . Would not drain water.
I have a Splendid Washer/Dryer combo Model # WD802.
The water is not draining. I have taken the filter out, cleaned it, still does not drain. Gets to the drain cycle and does not go any further. Same in every cycle.
Anyone with suggestions for repair ? Thanks
Aug 01, 2011 | Washing Machines
My washer lg wd-3245rhd will not drain, not even from the manual hose close to pump filter.
You have 2 problems. The manual drain hose is plugged with debris and cannot drain out. You will have to pull the hose out and clean it out.
The other problem is the either drain filter is plugged or the drain pump is broken. You will have to pull the drain filter out and allow all the water to pour onto the floor to check the drain filter. If the drain filter is clean, then you have a broken drain pump and needs to be replaced.
Good luck
May 26, 2011 | LG WD-3245 Front Load Washer / Dryer
Where is the lint filter for the LG Intellowasher 7.5kg (model WD-8016C)?
Hi just read your posting.I have worked on these machines before and I don"t recall this model having a lint filter.I know it has a drain pump filter and filters in the inlet hoses.Are you getting a lot of lint on your clothing?I will endeavor to find out definitively whether your model of machine has a lint filter and I will re post the solution.
Sep 18, 2010 | Washing Machines
LG WM-14225FD - making bad grinding type noise when in use
it will be your pump that circulates the water. i have had mine replaced four times during its 6 year life! its common, not to be confused with the drain pump.
Aug 06, 2010 | LG Washing Machines
My lg wm 14225fd is making a banging popping
this sonde like the drum needs to be rebalenced this needs to be done once a yr. you well need to call a repair person its covered under your warrenty.
Dec 22, 2009 | Washing Machines
LG WM 14225FD eu code
EU --- error means ---Unbalanced load is sensed three times during a spin operation. to resolve the issue ----Open lid. Rebalance laundry load and close lid.· Check wiring harness
· Check unbalance switch
· Check circuit board
Mar 14, 2009 | LG WD-1280FHD Front Load Washer
Lg intellowasher DD 7.5kg WM14225FD error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Oct 01, 2008 | Washing Machines
Washing Machines Logo
71 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
