Question about Coleman Hot Water On Demand
My water pump doesn't work. Our unit is nearly 6yrs old and I have installed a new battery and fully charged it. I have removed the filter on the pump and rotated the impeller. I discovered that the fuse on the circuit board had blown and I have replaced it thinking this was my problem but the pump still didn't work. I discovered that the pump works if connected to a separate power supply. The whole unit works successfully if the pump remains connected to a separate power supply. The unit doesn't appear to be sending power to the pump. Do you have any suggestions?
I found that my pump had siezed. This had caused the fuse to blow. Easy to replace. You have to open unit to get to it. Once fixed I used CRC to loosen corroded pump motor by spraying directly onto impala through the water intake. Waited an hour, plugged in and gave the pump a tap on the ground and away she went. Did leave a bad taste in water for a short time. Still good months later. Ps. If you don't use it, you loose it. Go away more often. :)
Posted on Jul 21, 2012
There is a wire that runs to the connection of the impeller pump to the unit, my guess is that it is probably touching the side of the copper element and has melted. The other possibilities are that the tiny circuit board behind that connection has come off or the connector at the other end (near the main circuit board) has detached somehow. Hope this helps
Posted on Aug 31, 2010
When I changed my filter in my Whirlpool refrigerator, my refrigerator stopped making ice and dispensing water. How do I get it to start back making ice and dispensing water.
If you still have the old filter replace the new with the previous. If all works OK check new filter for blockage or manufacturing defect. Usually most units will work with no filter installed.
It is likely that you have not fully assembled the new filter in the location.
The filter can be removed and there should be no leak and the ice maker and water dispenser should work just like before except the water is not filtered. This feature is available for customers who have whole house filters.
Hope this helps?
Nov 22, 2016 | Whirlpool Refrigerators
Camera switches on for a second and then swtches off btterey is fully charged
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
When trying to charge battery green light flickers for hours
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare V1073 Digital Camera
The camera wont turn on
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 05, 2010 | Kodak MX1063 Digital Camera
Hello
Jan 02, 2010 | Kodak EASYSHARE M1063 Digital Camera
It will not switch on, even with fully charged batteries
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 02, 2010 | Kodak EasyShare M853 Digital Camera
Can't charge battery. The battery symbol is red. What do I do?
Dec 31, 2009 | Kodak EASYSHARE M340 Digital Camera
The lens will not go back in and it flashes a green light in the back. It has not been dropped and it only is one year old?
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 31, 2009 | Kodak EASYSHARE M1063 Digital Camera
Battery will not charge
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair, order a new battery, charger or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 31, 2009 | Kodak MX1063 Digital Camera
Coleman Hot Water On Demand Logo
1,790 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
