Question about Watches
In the top screen (where the date and day usually located) thers a "open" sine and the watch is not responding to any button the time display is the only thing that still works
    Sergeant:
  • 209 Answers
What make is this watch? sounds like the back casing is partially open.
Posted on Aug 29, 2010
I had this problem and managed to fix it. There is a small metal plate locate inside the back cover of the phone that can be knocked out of position. The small plate should be in contact with the two screws in the top right hand side of the watch (when back plate is off).
To remove back plate you must remove the strap. To do this you must remove the four pins that connect the strap to the watch body. Take out the pins and set aside. The two plastic inserts can now be removed.
Remove the four screws and remove the back plate. Be careful not to lose screws, rubber seal and small plate.
Reglue the small plate to back plate and allow to set.
Reassemble watch in reverse order and watch should work as normal.
Good luck
Posted on Oct 13, 2011
The date on the f91w watch it's wrong, how can I modify it. Thanks in advance for your help.
The time or date is adjusted by pressing the lower left button three times to bring the watch to time adjustment mode. This causes the seconds to flash on the display. The top left button is pressed to cycle through seconds, hours, minutes, month, date, day, and normal mode. The right button is then pressed to adjust the flashing value displayed. When the adjustments are finished, the bottom left button is pressed repeatedly until the watch returns to normal mode.
Feb 28, 2011 | Watches
How do you get the time from military to normal? and how do yo set the date and time?
  1. Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  2. Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  3. Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  4. Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  5. Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
Sep 19, 2010 | Watches
How do I get my WR 100 ft model # AW60724W off army time.
Aug 31, 2010 | Watches
Trying to convert to military time
Best regards. Jewel
Aug 30, 2010 | Watches
How to change from military time back to regular time on a digital indigo watch with 4 adjustment buttons?
Thank you for contacting FixYa.<br /> <ol id="ecxintelliTxt"> <li id="ecxjsArticleStep1"> Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.<br /></li> <li id="ecxjsArticleStep2"> Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.<br /></li> <li id="ecxjsArticleStep3"> Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.<br /></li> <li id="ecxjsArticleStep4"> Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.<br /></li> <li id="ecxjsArticleStep5"> Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.<br /></li></ol> Contact TIMEX for further assistance at:<br /> http://www.timex.com/info/Product_Instruction_Guides_Downloads
Aug 25, 2010 | Timex 1440 Nylon watch
How do you change the time setting to 24 hours?
  • Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  • Step 2 Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  • Step 3 Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  • Step 4 Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  • Step 5 Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
  • Aug 17, 2010 | Columbia All Sport Digi Watch l
    I have purchased some cheap wrist watches from Hong Kong. They are the rubberised type with a digital display but have no instruction as to how to alter them. Can you help please?
    mcdevito75 here, I'm figureing you have only one (1) button on your watches, some, even cheap digitals have two (2) buttons, one of which is ususlly for a light. Some have two (2) buttons, one says MODE the other says SET. For one button (1) digitals, This will usually say set, when you press this button you should see the display change, to month then press set agin to see date, press set again to go back to time of day. NOW!! look for a DIMPLE, an INDENTATION on the side of the watch fairly close to the other button, press this DIMPLE in with a tooth pick, pin or the point of a pen, this is your MODE, press once, see the display flash, now with the set button, set whatever display is flashing, press MODE again, set this next display, when all displays, Month, Day, Date and time of day, hour and minute are set, press MODE again to see steady display. when you press set now, you can see the corrected display, press the set button for each display you want to view until you come back to the time of day display. That"s it.
    Jul 18, 2010 | Watches
    Change day but not date on Timex Expedition
    HI..
    HERE IS STEPS FOR SETTING OF YOUR WATCH... STEP3 EXPLAINS THE SETTING OF DAY,DATE.....
  • Step 1 Push in the lower right button until you see the seconds flash. Press the upper right button to run the seconds display down to zero. Push the bottom left button to get into the mode to set the hours. Press the top right button to scroll through the numbers. Watch that you choose a.m. or p.m. correctly.
  • Step 2 Press the bottom left button to get into the mode to set the minutes. Again, push the top right button to scroll through the numbers until you reach the correct time.
  • Step 3 Repeat the process from Step 2 four times to set the month, date and day of the week and to change to military time if you wish. Push the bottom right button to save your settings. You'll notice the colon between the numbers will start to flash.
  • THANK YOU
  • Jul 28, 2009 | Timex Expedition Outdoor Athletics Watch...
    I am trying to reset my T Touch watch from Tissot and can not find book. need to reset time and also how to convert from metric to US standards, like ferinhit and from meters to feet.
    SET TIME:
    1. Activate Crystal
    2. Tap center of screen until digital time comes up
    3. Press and hold top button (+) until watch beeps, display will be flashing
    4. Use + and – key to adjust time. If several hours off, hold appropriate key and
    after first hour passes, only the hour hand will move.
    5. Make sure the digital display shows A or P for AM or PM
    6. When finished, touch center of screen again.
    SET DATE:
    1. Activate Crystal
    2. Tap center of screen until date appears
    3. Press and hold top + button until watch beeps and display flashes.
    4. Use + and – buttons to change date to correct one.
    5. Make sure to set time first, if you set date first, you run the risk of the date
    changing at noon rather than midnight.
    Nov 26, 2008 | Tissot PRS 516 T91142651 Wrist Watch
    Timex 1440 sports watch, WR50M
    In "Time Mode" when time is displayed, hold the "mode" button until the alarm flashes. Press the "mode" button again and the display should change to the seconds flashing. Press the st/stop button to change location between seconds, minutes, hours, date, month, and day. Use the lap/reset button to make any changes.
    Feb 15, 2008 | Timex 1440 Nylon watch
    Watches Logo
    305 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
