Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
IO Magic 250gig external hard drive
It just gives me a blinking blue light and a clicking sound when I turn it on. Nothing else- is it dead?
  • 1 more comment
  • Brocktune May 11, 2008
    blinking blue light. won't recognize
  • Anonymous Jun 06, 2008
    Yes! Me too! It turns on, but it just beeps and is not recognized by my computer.
  • compnerd08 Jun 11, 2008
    ****.. same problem here!!! so one with a brain please help us!!!!! PLEASE!!!!
    Problem Solver:
  • 10 Answers
Unfortunately the hard drive within the external case has died. The clicking noise you can hear is the read / write heads trying to find anything on the platter and failing, this means that any files that were on the drive are lost. There are many tricks on the net that give hope of recovering data off a dead hard drive but most just corrupt the data completely. If you have files that you must have and can afford the extremely high price for data recovery there are services available through most hard drive manufactures, most notably through Seagate.
Posted on Jul 02, 2008
My I/O Magic Gigabank 500 was tipped over by my daughter. It now beeps intermittently and is not recognized by my computer.
it is possible you have a bad drive now as they cant be moved while on. However, turn it off let it cool down. Turn off the computer it was on. now disconnect it from both Data and wall for hard drive. give it say 20-30 minutes. put it back in the correct position, and try turning it on. after it has come up to speed plug it back into the computer. if you hear a sound try to compare it to one of these. you will notice that they have a play button next to the sounds.
Also IO magic isn't the hard drive manufacture IO uses other brands of hard drives to put inside their units. http://datacent.com/hard_drive_sounds.php these guys have a great sound of some failed drives.
if the drive can reset itself then all will be back to normal. if not you will need to do a drive test call them to find out what they recommend.
http://www.iomagic.com/
if western digital http://support.wdc.com/product/download.asp?wdc_lang=en
Jun 22, 2011 | IO Magic Corporation Computers & Internet
My computer wont recognize my external hard drve and the io magic light is blinking
Try connecting the external hard-drive to a different computer. If it still fails, and it is still under warranty, then exercise the warranty to get it replaced.
If the warranty has expired, open the case, and remove the disk-drive, disconnecting it from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some desktop computer, to see if the disk is recognized.
If it is, then the USB-to-disk-drive adapter has failed, and you could go to any computer-store to buy a new external case and adapter, and mount your disk-drive inside the new case, and work with your files.
If the disk-drive is not recognized, check the warranty on the disk-drive itself.
Jun 24, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Not recognizing external harddrive in "my computer". I/O magic blue light continually flashes blue instead of staying solid light
There are a few possibilities, the fact the light is blinking generally means the power adapter is fine.
The options left are a faulty driver in your PC, a failed circuit board in the enclosure or a failed circuit in the drive itself.
First try the drive on a different PC and see if it works. If it does reply back and we can look into the failed driver. If it doesn't then take it to your local PC shop and have the technicians move the hard drive into a new enclosure.
If it works in the new enclosure buy the enclosure and your on the way. If it doesn't, then the hard drive itself is the problem. If that is the case you will need the help of a data recovery pro to retrieve your data. If this is the case reply with your location(Country, State and City) and I will assist you in finding a reputable pro to assist you.
Hope this helps FixYa,
Chris
Oct 26, 2009 | IO Magic Corporation GigaBank (I250HD35)...
Blinking light in unusual pattern and ticking/clicking sound
TH eclikcing sounds like the heads are uffering from STICKTION give the drive a gentle but sharp jolt with the palm of your hane and see what happens
Aug 09, 2009 | SimpleTech (sti-u2f36/250) 250 GB Hard...
GigaBank 250 GB USB 2.0 External hard Drive - How to open case ?
Remove the cover plate from behind the drive (where the plugs and on/off switch are.) You have to then remove the 2 screws. After that pull on the end with the blue lights to slide the hard drive out. If you have a tower computer, you can permanently install the hard drive and it should work fine as a secondary drive. Just make sure the jumper pins are set to "slave".
Mar 29, 2009 | IO Magic Corporation GigaBank (I250HD35)...
My 500 gig io magic doesnt respond any way it can be fixed?
Is the blue light blinking? I had the same thing occur to my I/O Magic 250 GB USB drive a couple of days ago. I did an online chat with I/O Magic tech support and the guy said you can RMA (return) it if it's in warrantee, but otherwise too bad. Mine is out of warrantee. Since the enclosure contains an ordinary hard drive inside, just carefully peel off the little metal plate at the back of the unit, undo the two screws and slide out the drive. The are two plugs and four screws to free the drive. To get your data back once you've got the drive out, you've got three choices: buy a new enclosure ($20+), buy a toaster ($50) (it's like an enclusre, but you just pop a drive into the top, like bread into a toaster), or open up your computer and connect the drive directly as any other. Oh and don't buy another I/O Magic product again.
Dec 28, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Blinking blue light
the only blue light that i know blinks is the Kmart blue light special .. we need model of things you're working with to properly diagnose.
is it external drive ? with a blue light blinking ? is it connected in usb ? sounds like if its external drive with blinking light could be bad hard disk or bad controller card inside that translates ide to usb.
Jul 29, 2008 | Computers & Internet
IO Magic Drive power replacement
All you need to do is ask at a computer parts store for an external hard drive enclosure.Take the hard drive with you and they will be able to give you the correct size, there are 3 sizes available, 1.8" (has a drive the same as an ipod in it), 2.5"(has a laptop /notebook hard drive in it), and a 3.5"(has a full size desktop hard drive in it).
The other option is you could just completely remove the drive from the io magic case and install it into your computer as an extra drive.
Jul 02, 2008 | IO Magic Corporation GigaBank (I250HD35)...
My PC Will Not Recognize My External Hard Drive ...
Not sure if this will help, but was having the same problem. I separated the power cord to the AC adapter brick and reconnected it. My computer immediately recognized it!
Sep 06, 2007 | IO Magic Corporation GigaBank (I250HD35)...
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
487 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Brian Sullivan
Brian Sullivan
etrc_new
Joe M
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
