Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water leaking from freezer down back wall inside fridge
Model# ET19RKXGW02
Serial# EJ1127868
Date of MFG 03-99
Water is leaking from the freezer and gathering under both crisper's in the fridge. I have changed temps, cleaned out and thawed still no luck.
  • 5 more comments
  • marymarley May 15, 2008
    I have the same problem with my Whirlpool with top freezer. I have water leaking down from freezer onto inside back of refrigerator. I catch the water in a container sitting on top shelf, back of refrigerator. Any solutions yet??
  • converter May 18, 2008
    Water leaking from freezer into refigerator at back
  • btleonard May 18, 2008
    Same problem, plus ice machine only fills half way. I assume that is the cause of the leak.
  • NINERLAR May 27, 2008
    The back of the unit is sealed with sheet metal from top to bottom. When I remove the entire sheet metal plate, where would this drain line be?
    And how do you unclog it?
    NINERLAR
  • NINERLAR Jun 18, 2008
    It took me most of the day. After cleaning out and un-plugging it from the wall for 3 - 4 hours. I was able too find the drain pipe after only removing the 'bottom' back plate. I could only see about 8" of the drain line and noticed NO WATER at all in the drain pan. I also removed the 'floor' pan inside the freezer. It's only attached with 2 screws. When I took out the 'floor pan' I found about 3/4" thick sheet of ice. Under that ice was a solidly frozen drain pipe. After getting all ice out (scraper & blow dryer) and making sure the drain pipe was clear (I poured water down it and saw it go into the pan) Put it all back together. 3 weeks now no water. Thank you for all the help.
  • Cornell Mickley Sep 24, 2011
    Do you have any pictures of what you you explained about your leaking problem? I am having the same issue.
  • Anonymous Mar 12, 2014
    Over about a 3 week period of time, small amount of water gathers and freezes on freezer floor. Until it is full then starts to leak on floor outside unit.
  • 828 Answers
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
Posted on May 27, 2008
I have a GE Profile Perfomance Model 22 ( TN22PRCBRBS)..I`ve had it for 11 years and I`ve noticed a leak developing from my ice maker onto the base of the freezer..I`ve had to chisel the ice that continously forms everyother day..I checked to see if I could investigate but I can`t get to the source ,which is the water line connecting to the ice maker itself..Any suggestions?
Posted on Jun 18, 2008
Another question by me
Most likely that light is caused by a refrigerant leak somewhere in the fridge system. Most likely the fridge evaporator, but you would need a leak detector to confirm this. It could also be that the fan to cool the compressors is not running all the time, or that the compressor itself is weak. Do you have any error codes? Is there a ball of ice forming on the back wall of the fridge section on the left side towards about halfway down from the top? what is build date on the serial tag, located on the frame of the fridge inside the freezer door at the top. Good luck, hope this helps.
Oct 16, 2013 | Cell Phones
Water accumulating under veg.bins. Do not have ice maker hooked up. Whirlpool ET20DKXXN10 Model Mfg. date 1992.
you have a blocked drain in the freezer.when the machine goes into defrost a heater comes on and melts any ice that built up on the evap coil,the ice melts and goes down the drain and into a pan at the bottom where the compressor and condenser coil is and evaporates from the heat,your drain is blocked so the water can't go down the drain and it has nowhere to go but down into the fridge section.unplug the machine,remove all the food out of the freezer,remove the shelf and the inside back wall of the freezer.you might have to heat up the back panel with a hair dryer to get the wall out,when you have the back wall off melt any ice with the hair dryer,now you have to clear the drain,i use a steemer to blow down the drain but if you don't have a steemer stick a screw driver into the hole and the metal on the driver will heat up and help melt the ice,when you think the ice is melted in the hole get a turkey baster or something that will blow or push anything in the drain out,then pour hot water into the hole,if the water drains down then you're done if not keep hitting it with heat and hot water and try to clear the drain.hope this helps.
Sep 13, 2011 | Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
We have a Kenmore coldspot Refrigerator (Top Freezer), Model # 10570102001 , Mfg date 01/01. Water is leaking on the inside of the fridg from the top. There's an opening in the back at the very top and...
you have a blocked drain.when the machine defrosts the ice melts off the coil and the water drains down to the bottom of the machine where the compressor is and the condenser coil.it gets hot down there and the water evaporates.your drain is blocked and the water isn't making it out of the freezer.take out all the food in the freezer,remove anything else in there and remove the back inside wall of the freezer,unplug it or shut down the control,then with a hair dryer melt all the ice,i use a steemer to clean out the drain but you can use a baster or anything that will blow through or force air down the drain to clean it out.when you think it's clear pour hot water down the drain hole to see if the water goes down the hole,if it does then it's clear if it doesn't keep blowing through the line,when you clear it you can buy a heater,all it is is a piece of metal that raps around the heater,you stick it down the hole so when the heater comes on the metal heats up and the water wont freeze in the drain line.you need like a 6 inch long piece of wire from a cable wire or from a wire that you use to hook up a lite,use the ground wire or the copper piece in the cable or lite wire,strip off the casing and stick the wire down the hole and cut it with enough wire to rap around the heater and this should take care of your blocked drain.a steemer works the best,stick it in the hole and blast the steem down through the drain,it clears everything out of it.good luck
Jan 29, 2011 | Kenmore Refrigerators
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Ice maker is leaking out the back of fridge at joint
There may indeed be blockage inside the joint/or supply line. Depending on the hardness of your water, there can be a considerable amount of calcium or other mineral deposits fouling the line. This sediment will be inside and may not be noticeable from the outside.
However, if you notice crusty deposits anywhere around where you see the leaking this is a strong indication that you may have sedimentary build-up inside.
In any case, the best long-term solution is to replace the joint and evaluate the line surrounding the joint. All the parts involved can be purchased at a local hardware store, and they are not very expensive at all. Attaching them is pretty straightforward as well.
I hope this helps.
Aug 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Water is pooling inside at the bottom
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section (not on all models, but this is the most common way), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups (in the top back of the fresh food section) can be removed for cleaning. A turkey buster can be used to help clean out the drain system. Fill the buster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On an S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now (Whirlpool makes many of the Kenmore branded refrigerators) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Thanks
Rylee
May 30, 2009 | Refrigerators
Water leaking from inside of refrig.I think it could be Ice maker
defrost the freezer drain tube with a hair dryer
May 09, 2008 | Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
730 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
