Question about Sennheiser HD430-03 - Ear Cushions for HD430 Headphones
I store my hd430 headphones in a cool cabinet, but I had not used them for a few years. When I removed them from the box, I noticed the ear cushions were greasy and crumbling. Some fell on the chair; I tried to clean it up, but it smeared, and could not be completely cleaned from the vinyl. The cord had begun to crumble; likely the fluid has this effect. I suspect the ear cushions leaked and destroyed everything. The headphones were evidently defective; the leaked fluid trashed everything. As I purchased them several years ago, there is no replacing them. I'll have to look for another headset. I will not get another Sennheiser headset as I can not forget the furniture stain and the way the leaked fluid affected clothing. What happened was unbelievable. I had noticed a slight static crackling on the right side when I last used them; possibly it was caused by the start of the leak. Unbelievable! I'd only used them 3times and always returned them to the box such a disappointment.
  • Sennheiser Master
  • 5,444 Answers
You might want to get in touch with the makers. I'd write them a letter! You never know they might send a pair free or something! I certain they would welcome the feedback anyway!
Posted on Aug 30, 2010
How to clean my white solo 2 beats headphones ear cushions?
hi. remove the cushions from the headphone and use a wet cloth with a little liquid soap and water, do not make too wet and do not get water into the headphones. alternatively you can buy replacement cushions for this headphone via the internet cost about 15 dollars us.
I hope this was useful.
Feb 24, 2015 | Audio Players & Recorders
Severe squelch in left ear phone
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a significant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the shape of the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
If the foam in the ear cushion has weakened/deteriorated to the point that it no longer has it's original shape, (in particular the lower half of the ear cushion), the size and shape of the air chamber inside of the earcup is directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
It is probably time to replace the ear cushions. If so, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Aug 29, 2013 | Bose QuietComfort 3 Acoustic Noise...
Ear cushion is off the product at time of purchase
You can try returning the headphones to the store for replacement but if that doesn't work the cushion can be reinstalled unless it is damaged
May 31, 2013 | ifrogz EarPollution Plugz Headphones
How to replace ear cushion on bose QC 3 headphone
The ear cushions are held on the earcup with six snap fasteners, three on each side. To remove the ear cushion, simply pull it away from the earcup carefully so that you do not break the plastic snap tabs.
It should not be necessary to pry the ear cushion off with a sharp object, but if you do, be careful. There is also a thin gasket seal between the earcup and the ear cushion, take care not to damage it.
If you need to replace the ear cushions with new ones, they are available from Bose for $35/pair.
or $5.69/pair.
Apr 02, 2013 | Bose QuietComfort 3 Acoustic Noise...
Ear pads falling apart
Please follow the proper instructions below
Ear cushion reattachment
If the ear cushions come off your headphones,
reattach them as follows:
1. Fit the mounting flange inside the rim of the ear cup.
2. Make sure it attaches smoothly and uniformly within the entire ear cup. (Do not remove the ear cup lining material).
Ear cushions may need to be replaced due to normal wear and tear. To order replacement ear cushions, call 1-888-865-2700.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Bose 41213 Headphones
I have had my headsets for 3 years, they work well, I have just noticed that the left ear pad is detaching from the base. How do I get fixed?
The ear cushions are attached to the earcup with plastic tabs that snap into the plastic in the earcup. The lower snaps may be unfastened. Try pressing the ear cushion firmly to the earcup around the lower edge to refasten the snaps. Do not press in the middle of the ear cushion - you may damage the internal microphone.
If this fails, you will need to remove the ear cushion by pulling it off the earcup and inspect for broken plastic where the tabs are on the ear cushion or where the tabs attach to the earcup. If a tab is broken on the earcup, replacement earcups are available from Bose for $35 per pair.
http://www.bose.com/controller?url=/shop_online/headphones/noise_cancelling_headphones/accessories/qc3_earcushionkit_acc.jsp
If the plastic in the earcup is broken, you can try to repair it or you can contact Bose about getting it repaired or replaced.
Jun 11, 2011 | Bose QuietComfort 3 Acoustic Noise...
Feedback sound like wind noise in right headphone of QC3, starts quietly and gradually gains in strength. Sometimes disappears, then comes back again. No sign of moisture in battery compartment. Any ideas?
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the lower half of the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When the foam has weakened or deteriorated to the point that the size and shape of the chamber cannot be maintained, more of the speaker sound is directed toward the microphone than the design can compensate for causing audio feedback to occur. This also happens when the lower half of the ear cushion is compressed. Since this is occuring during normal use,
it may be time to replace the ear cushions. They are available from Bose for $35 per pair.
Sep 18, 2009 | Bose QuietComfort 3 Acoustic Noise...
How do I install batteries.
remove the ear cushion from the earcup, twist counter clockwise a quater turn untill u overcome a slight resistance and lift off, underneath u will see 2 batteries one either side of the driver.(i think it is the right one both cushions are removable anyway. The batteries should be NiMH rechargeable not standard AA do not use AA .the batteries recharge when u put the headphones back on the cradle takes about 18 hrs
u can use a external charger which is probably quicker. There is built in overcharging protection so this should not be a problem.
Sep 02, 2009 | Audio Players & Recorders
I lost one of the ear cushions of my insignia head phones
hi u can get these ear cushions in all bluetooth  accessories shop...
Feb 09, 2009 | Insignia Bluetooth Wireless Headphones...
Open Questions:
See all Sennheiser HD430-03 - Ear Cushions for HD430 Questions
Sennheiser HD430-03 - Ear Cushions for HD430 Headphones Logo
184 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
